Vaillant vSMART Thermostat
djreesing
Target OS: Raspberry Pi
Domoticz version: 3.6653
Post by djreesing » Wednesday 28 June 2017 8:24
Is it possible to integrate the Vaillant vSmart thermostat in Domoticz (https://www.vaillant.nl/consument/produ ... 17792.html). It is actually a rebranded Netatmo thermostat, so maybe it shares the same API?
I noticed it is supported by IFTTT, but I would like to control it from Domoticz directly instead of through IFTTT if possible.
Willem81
Re: Vaillant vSMART Thermostat
Post by Willem81 » Sunday 17 September 2017 8:04
Same interest here! Would be great.
Jazzle
Post by Jazzle » Saturday 21 October 2017 0:17
Yup i'd like that too!
Jazzle
Post by Jazzle » Tuesday 06 February 2018 0:19
djreesing wrote:Is it possible to integrate the Vaillant vSmart thermostat in Domoticz (https://www.vaillant.nl/consument/produ ... 17792.html). It is actually a rebranded Netatmo thermostat, so maybe it shares the same API?
Djreesing, had any succes so far? Did you try adding it as a netatmo thermostat?
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
Jazzle
Post by Jazzle » Tuesday 06 February 2018 0:25
See viewtopic.php?t=6846
Jazzle
Post by Jazzle » Sunday 18 March 2018 16:25
just installed my V-smart communication module + thermostat to one of my boilers. It tried to add it as Netatmo thermostat but unfortunately doesn't show anything.
Any developments, ideas or ways i can help for V-smart implementation in domoticz?
Jazzle
Post by Jazzle » Sunday 18 March 2018 18:21
Jazzle wrote:Hi all,
My apologies, I should think more before it write.. I have an rflink/ arduino 868MHz transceiver. I will make a debug log for the data from thermostat to communication unit (and if there is any data the other direction that too) and send it to the rflink team.
I do think it would be nicer to communicate through the wifi api, hope we will get there some day!
Jazzle
Post by Jazzle » Wednesday 28 March 2018 22:05
Over here (may i link to other fora?): https://community.home-assistant.io/t/a ... e/31858/17 someone has created a plugin for home assistant,
Would the python script need much modification for domoticz?
https://github.com/jabesq/netatmo-api-p ... ont:master
https://github.com/home-assistant/home- ... dumont:dev
I have no developer experience but will read into
Jazzle
Post by Jazzle » Thursday 29 March 2018 8:34
To continue, let me first define what i want domoticz to be able to do with the vsmart thermostat:
Required:
- read online/ offline status
- read measured temperature
- read setpoint temperature
- set setpoint temperature
Niice to have:
- read boiler status: heating/idle
- read historical data (temperature vs heating graph from app, data stored on vaillant/ netatmo server?)
kofec
Post by kofec » Thursday 29 March 2018 9:03
Jazzle
Post by Jazzle » Friday 30 March 2018 12:44
Thanks, though if i understand correctly those links are about OTGW or directly controlling the boiler via ebus. In that solution the whole vaillant vsmart system is redundant/ bypassed.
I want to keep using the vaillant system (since other users need to be able to set thermostat using the buttons on the physical thermostat).
