dutch smartmeter gas usage 4.294.965m3 a day (problem solved)
luberth
Target OS: Raspberry Pi
Domoticz version: 4.9700
Post by luberth » Friday 27 April 2018 8:13
screenshot
screen
Hello
i have bought a raspberry pi 3b smartmeter kit from sossolutions https://www.sossolutions.nl/slimme-mete ... berry-pi3b
landis gyr e350 smr5
wireles gas meter connected to above (uniflo g4srt smr5 flonidan)
electric is working wel (exept that i am a bit dissapointed that the grapic day log is only a week long)
total gas use under button other devices is working wel 4.003m3 total used (i do not use much gas 4m3 in 14 days)
but the graphic log tells me i have days with 4milion m3 used or even much much more a value wich i can not pronounce
and also the weeklog is not correct
some data follows
am i the only one with this problem?
download/file.php?mode=view&id=15762
2018-04-24 16:00:00 0
2018-04-24 17:00:00 0
2018-04-24 18:00:00 0
2018-04-24 19:00:00 0
2018-04-24 20:00:00 0
2018-04-24 21:00:00 0
2018-04-24 22:00:00 0
2018-04-24 23:00:00 0
2018-04-25 00:00:00 0
2018-04-25 01:00:00 15744.284
2018-04-25 02:00:00 18446744949882880
2018-04-25 03:00:00 0
2018-04-25 04:00:00 0
2018-04-25 05:00:00 0.087
2018-04-25 06:00:00 0.077
2018-04-25 07:00:00 0
2018-04-25 08:00:00 0
2018-04-25 09:00:00 0
2018-04-25 10:00:00 0
2018-04-25 11:00:00 18446744949882880
2018-04-25 12:00:00 2.18
2018-04-25 13:00:00 0
2018-04-25 14:00:00 0
2018-04-25 15:00:00 0
2018-04-25 16:00:00 0
2018-04-18 00:00:00 4294965.219
2018-04-19 00:00:00 4294965.057
2018-04-20 00:00:00 0.249
2018-04-21 00:00:00 0.296
2018-04-22 00:00:00 4294964.376
2018-04-23 00:00:00 0.14
2018-04-24 00:00:00 0.382
2018-04-25 00:00:00 4294965.595
2018-04-27 08:06:18.130 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:20.124 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:21.130 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:22.119 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:23.123 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:24.130 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:26.123 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:27.130 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:28.119 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:29.124 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:30.131 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:31.789 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(51-0:2.8.1(000004.900*kWh)" is oversized
2018-04-27 08:06:35.124 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:35.971 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(233.0-1:96.1.0(4730303339303031383030323534303138)" is oversized
2018-04-27 08:06:37.772 P1 Smart Meter: Dismiss incoming - value in line "0-1:24.2.10-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 08:06:38.954 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(2330-1:24.1.0(003)" is not a number
2018-04-27 08:06:44.122 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:45.124 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:46.125 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:48.122 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:49.124 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:49.940 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(233.01-0:21.7.0(00.047*kW)" is oversized
2018-04-27 08:06:50.131 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:51.121 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:53.130 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:54.120 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:55.125 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:56.130 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:58.124 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:06:59.125 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:00.131 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:01.120 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:02.125 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:04.119 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:06.131 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:07.126 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 08:07:07.130 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 08:07:07.137 (Slimme Meter Kabel) P1 Smart Meter (Gas)
2018-04-27 08:07:08.132 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 08:07:08.137 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 08:07:10.121 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:10.745 P1 Smart Meter: Dismiss incoming - value in line "0-1:24.2.1(180-0:1.0.0(180427080709S)" is not a number
2018-04-27 08:07:12.976 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.0-1:24.1.0(003)" is not a number
2018-04-27 08:07:15.133 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:17.126 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:18.131 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:21.132 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:23.126 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:24.123 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 08:07:24.127 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 08:07:25.123 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:26.128 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 08:07:26.131 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 08:07:27.131 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:29.126 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:31.120 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:33.131 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:35.125 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:39.127 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:40.132 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:41.121 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:43.127 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:45.124 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:45.775 P1 Smart Meter: Dismiss incoming - value in line "0-1:24.2.1(180427080503S)0-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 08:07:46.127 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:48.124 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:49.126 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:51.120 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:56.133 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:57.122 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:07:58.125 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:00.133 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:02.125 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:04.133 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:07.132 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:08.120 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:09.125 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:10.883 P1 Smart Meter: Dismiss incoming - value is not delimited in line "1-0:2.7.0(00.00"
2018-04-27 08:08:12.125 P1 Smart Meter: Dismiss incoming - value is not delimited in line "1-3:0.2.8(50!6045"
2018-04-27 08:08:14.121 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:15.127 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:17.121 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:18.125 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:20.121 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:21.127 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:22.133 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:23.121 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:24.128 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:27.126 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:28.852 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(000-0:96.7.9(00000)" is not a number
2018-04-27 08:08:29.121 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:31.900 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.2(0001-0:32.36.0(00000)" is oversized
2018-04-27 08:08:32.123 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:34.133 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:35.123 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:36.126 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:37.133 (smartone) P1 Smart Meter (Power)
2018-04-27 08:08:37.134 (smartone) General/Voltage (Voltage L1)
2018-04-27 08:08:38.123 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:40.134 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:41.123 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:42.127 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:43.139 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 08:08:43.143 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 08:08:44.122 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:45.973 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.00-1:96.1.0(4730303339303031383030323534303138)" is oversized
2018-04-27 08:08:48.128 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:49.134 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 08:08:50.123 P1 Smart Meter: Dismiss incoming - CRC failed
luberth
Re: dutch smartmeter gas usage 4.294.965m3 a day
Post by luberth » Friday 27 April 2018 10:12
bankroet
luberth
Post by luberth » Friday 27 April 2018 11:45
2018-04-27 11:40:49.670 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2018-04-27 11:40:49.670 Build Hash: 494fff7, Date: 2017-07-30 12:19:41
2018-04-27 11:40:49.670 Startup Path: /home/pi/domoticz/
2018-04-27 11:40:49.867 EventSystem: reset all events...
2018-04-27 11:40:50.125 PluginSystem: Started, Python version '3.5.3'.
2018-04-27 11:40:50.141 WebServer(HTTP) started on address: :: with port 8080
2018-04-27 11:40:50.153 WebServer(SSL) started on address: :: with port 443
2018-04-27 11:40:50.154 Proxymanager started.
2018-04-27 11:40:50.195 TCPServer: shared server started...
2018-04-27 11:40:50.195 RxQueue: queue worker started...
2018-04-27 11:40:52.196 P1 Smart Meter: Using serial port: /dev/ttyUSB0
2018-04-27 11:40:52.200 P1 Smart Meter: Using serial port: /dev/ttyUSB0
2018-04-27 11:40:52.203 P1 Smart Meter: Using serial port: /dev/ttyUSB0
2018-04-27 11:40:52.206 EventSystem: reset all events...
2018-04-27 11:40:52.206 EventSystem: reset all device statuses...
2018-04-27 11:40:52.392 PluginSystem: Entering work loop.
2018-04-27 11:40:52.410 Python EventSystem: Module not found - Trying to initialize.
2018-04-27 11:40:52.410 Python EventSystem: Initalizing event module.
2018-04-27 11:40:52.411 EventSystem: Started
2018-04-27 11:40:53.059 P1 Smart Meter: Meter reports as DSMR 5.0
2018-04-27 11:40:55.277 P1 Smart Meter: Found gas meter on M-Bus channel 1
2018-04-27 11:40:55.528 Incoming connection from: ::1
2018-04-27 11:40:56.059 P1 Smart Meter: Meter reports as DSMR 5.0
2018-04-27 11:41:03.304 P1 Smart Meter: Found gas meter on M-Bus channel 1
2018-04-27 11:41:04.277 P1 Smart Meter: Found gas meter on M-Bus channel 1
2018-04-27 11:41:08.060 P1 Smart Meter: Meter reports as DSMR 5.0
2018-04-27 11:43:57.071 P1 Smart Meter: Meter reports as DSMR 5.0
2018-04-27 11:45:25.911 Incoming connection from: 62.210.139.128
2018-04-27 11:46:16.396 Incoming connection from: ::1
2018-04-27 11:48:57.064 P1 Smart Meter: WARNING: got new message but buffer still contains unprocessed data from previous message.
2018-04-27 11:49:56.064 P1 Smart Meter: WARNING: got new message but buffer still contains unprocessed data from previous message.
2018-04-27 11:50:57.067 P1 Smart Meter: WARNING: got new message but buffer still contains unprocessed data from previous message.
2018-04-27 11:51:11.067 P1 Smart Meter: WARNING: got new message but buffer still contains unprocessed data from previous message.
luberth
Post by luberth » Friday 27 April 2018 11:57
Weer
Overige
Instellingen
Allemaal
Status
Probleem
Filter:
X
2018-04-27 11:41:02.463 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:41:03.447 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:04.101 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.80-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:41:04.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:07.452 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:09.066 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:41:10.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:11.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:12.210 P1 Smart Meter: Dismiss incoming - value is not delimited in line "1-0:2.7.0(00.00"
2018-04-27 11:41:13.100 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(50-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:41:14.267 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(236.01-0:21.7.0(00.034*kW)" is oversized
2018-04-27 11:41:16.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:17.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:18.450 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:19.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:21.447 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:22.452 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:23.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:24.449 P1 Smart Meter: Dismiss incoming - value is not delimited in line "1-0:2.7.0(00.!584D"
2018-04-27 11:41:25.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:26.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:27.194 P1 Smart Meter: Dismiss incoming - value is not delimited in line "1-0:32.7.0(236."
2018-04-27 11:41:27.448 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:29.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:30.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:31.450 P1 Smart Meter: Dismiss incoming - value is not delimited in line "0-1:24.2.1(18042711400!B133"
2018-04-27 11:41:33.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:34.451 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:35.454 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:36.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:37.450 (smartone) P1 Smart Meter (Power)
2018-04-27 11:41:37.452 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:41:39.461 (smartone) P1 Smart Meter (Power)
2018-04-27 11:41:39.462 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:41:40.451 (smartone) P1 Smart Meter (Power)
2018-04-27 11:41:40.452 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:41:41.457 (smartone) P1 Smart Meter (Power)
2018-04-27 11:41:41.458 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:41:44.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:47.452 P1 Smart Meter: Dismiss incoming - value is not delimited in line "0-1:24.2.1(18042711400!4788"
2018-04-27 11:41:48.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:49.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:50.448 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:52.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:53.242 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.001-0:32.7.0(235.0*V)" is oversized
2018-04-27 11:41:54.118 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(51-0:2.8.1(000004.900*kWh)" is oversized
2018-04-27 11:41:56.449 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:57.454 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:41:58.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:01.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:02.450 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:04.446 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:05.449 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:06.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:07.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:11.450 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:12.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:15.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:16.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:18.454 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:19.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:20.451 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:23.450 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:26.451 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:28.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:29.180 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.00-0:96.7.9(00000)" is not a number
2018-04-27 11:42:29.449 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:30.104 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(0-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:42:34.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:35.451 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:37.302 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(2360-1:96.1.0(4730303339303031383030323534303138)" is oversized
2018-04-27 11:42:37.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:40.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:41.452 (smartone) P1 Smart Meter (Power)
2018-04-27 11:42:41.454 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:42:42.456 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:47.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:48.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:49.286 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(230-1:24.1.0(003)" is not a number
2018-04-27 11:42:49.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:50.451 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:52.457 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:54.452 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:56.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:42:58.456 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:01.121 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(1-0:2.8.1(000004.900*kWh)" is oversized
2018-04-27 11:43:02.286 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(236.0-1:24.1.0(003)" is not a number
2018-04-27 11:43:02.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:03.450 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:05.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:06.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:08.158 P1 Smart Meter: Dismiss incoming - value in line "0-1:24.2.1(1804271141-0:2.7.0(00.000*kW)" is not a number
2018-04-27 11:43:10.456 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:12.452 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:13.106 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(50-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:43:14.448 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:18.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:20.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:21.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:24.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:25.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:26.454 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:29.150 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.21-0:1.7.0(00.025*kW)" is not a number
2018-04-27 11:43:32.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:33.457 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:34.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:36.457 (smartone) P1 Smart Meter (Power)
2018-04-27 11:43:36.458 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:43:38.452 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:39.457 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:40.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:41.150 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.1-0:1.7.0(00.024*kW)" is not a number
2018-04-27 11:43:41.454 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:42.457 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:43.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:44.452 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:45.457 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:46.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:48.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:49.457 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:50.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:53.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:55.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:43:57.103 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:43:57.454 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:00.104 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:44:00.168 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.2(000013.80-0:96.7.21(00002)" is oversized
2018-04-27 11:44:00.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:04.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:05.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:07.107 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.80-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:44:09.455 P1 Smart Meter: Dismiss incoming - value is not delimited in line "0-1:24.2.1(18042711400!965C"
2018-04-27 11:44:12.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:13.457 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:15.182 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.000-0:96.7.9(00000)" is oversized
2018-04-27 11:44:18.168 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.20-0:96.7.21(00002)" is not a number
2018-04-27 11:44:19.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:20.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:22.151 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.21-0:1.7.0(00.021*kW)" is not a number
2018-04-27 11:44:24.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:25.450 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:26.456 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:27.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:30.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:32.452 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:36.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:38.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:39.077 P1 Smart Meter: Dismiss incoming - value in line "0-1:24.2.1(180-0:1.0.0(180427114437S)" is not a number
2018-04-27 11:44:39.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:43.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:44.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:45.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:46.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:50.216 P1 Smart Meter: Dismiss incoming - value is not delimited in line "1-0:2.7.0(00.0"
2018-04-27 11:44:50.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:51.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:52.451 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:54.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:55.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:56.454 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:57.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:44:58.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:06.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:08.453 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:10.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:12.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:14.233 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.0001-0:32.36.0(00000)" is oversized
2018-04-27 11:45:15.107 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(500-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:45:17.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:19.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:21.457 P1 Smart Meter: Dismiss incoming - value is not delimited in line "0-1:24.2.1(180427114502S)(00!DEB4"
2018-04-27 11:45:22.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:24.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:25.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:26.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:27.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:28.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:31.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:32.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:33.459 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 11:45:33.463 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 11:45:33.468 (Slimme Meter Kabel) P1 Smart Meter (Gas)
2018-04-27 11:45:34.140 P1 Smart Meter: Dismiss incoming - value in line "1-0:1.8.1(00-0:96.14.0(0001)" is not a number
2018-04-27 11:45:35.467 (smartone) P1 Smart Meter (Power)
2018-04-27 11:45:35.468 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:45:35.469 (smartone) P1 Smart Meter (Gas)
2018-04-27 11:45:36.185 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0-0:96.7.9(00000)" is not a number
2018-04-27 11:45:39.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:41.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:43.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:46.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:48.457 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:50.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:52.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:53.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:54.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:55.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:56.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:45:57.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:01.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:06.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:07.456 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:08.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:10.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:14.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:16.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:19.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:21.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:24.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:25.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:26.456 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:27.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:28.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:30.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:31.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:36.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:37.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:38.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:40.465 (smartone) P1 Smart Meter (Power)
2018-04-27 11:46:40.466 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:46:41.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:42.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:44.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:46.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:48.156 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.21-0:1.7.0(00.017*kW)" is not a number
2018-04-27 11:46:48.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:49.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:51.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:55.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:46:58.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:01.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:03.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:04.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:08.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:09.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:10.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:11.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:13.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:14.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:15.251 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.0001-0:32.7.0(236.0*V)" is oversized
2018-04-27 11:47:16.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:18.457 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:21.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:22.457 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:23.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:24.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:25.456 (smartone) P1 Smart Meter (Power)
2018-04-27 11:47:25.458 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:47:25.459 (smartone) P1 Smart Meter (Gas)
2018-04-27 11:47:27.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:29.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:35.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:40.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:41.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:43.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:44.189 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.000-0:96.7.9(00000)" is oversized
2018-04-27 11:47:44.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:46.455 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:47.238 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.1-0:32.36.0(00000)" is not a number
2018-04-27 11:47:48.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:49.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:50.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:52.476 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 11:47:52.481 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 11:47:53.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:55.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:47:56.315 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.000-1:24.1.0(003)" is not a number
2018-04-27 11:48:00.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:01.152 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00:96.14.0(0001)" is not a number
2018-04-27 11:48:01.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:02.158 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.2(1-0:1.7.0(00.016*kW)" is not a number
2018-04-27 11:48:05.174 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.2(000010-0:96.7.21(00002)" is oversized
2018-04-27 11:48:05.459 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:06.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:07.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:09.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:10.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:14.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:15.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:16.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:18.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:19.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:21.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:23.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:24.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:26.158 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.1-0:1.7.0(00.016*kW)" is not a number
2018-04-27 11:48:29.143 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:48:29.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:30.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:31.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:32.460 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:36.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:38.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:39.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:42.462 P1 Smart Meter: Dismiss incoming - value is not delimited in line "0-1:24.2.1(180427114502S!1C73"
2018-04-27 11:48:45.192 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.2(00000-0:96.7.9(00000)" is oversized
2018-04-27 11:48:47.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:48.458 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:49.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:50.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:52.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:54.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:57.064 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:48:57.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:58.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:48:59.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:02.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:03.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:04.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:05.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:07.081 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:49:08.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:09.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:10.463 (smartone) P1 Smart Meter (Power)
2018-04-27 11:49:10.464 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:49:12.473 (smartone) P1 Smart Meter (Power)
2018-04-27 11:49:12.475 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:49:13.482 (smartone) P1 Smart Meter (Power)
2018-04-27 11:49:13.483 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:49:14.132 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(1-0:2.8.1(000004.900*kWh)" is oversized
2018-04-27 11:49:14.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:17.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:20.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:21.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:22.474 (smartone) P1 Smart Meter (Power)
2018-04-27 11:49:22.476 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:49:24.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:25.479 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 11:49:25.483 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 11:49:26.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:28.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:32.463 (smartone) P1 Smart Meter (Power)
2018-04-27 11:49:32.464 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:49:33.468 P1 Smart Meter: Dismiss incoming - value is not delimited in line "1-0:32.7.0(235.0!6D67"
2018-04-27 11:49:34.474 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:35.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:36.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:38.461 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:39.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:42.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:44.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:47.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:49:50.160 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.2(1-0:1.7.0(00.017*kW)" is not a number
2018-04-27 11:49:51.117 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.80-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:49:53.465 P1 Smart Meter: Dismiss incoming - value is not delimited in line "0-1:24.2.1(18042711450!D3E6"
2018-04-27 11:49:56.066 (smartone) P1 Smart Meter (Power)
2018-04-27 11:49:56.068 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:49:57.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:00.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:01.474 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:02.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:03.116 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.80-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:50:05.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:09.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:11.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:13.473 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:16.298 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(235.00-1:24.1.0(003)" is not a number
2018-04-27 11:50:17.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:19.475 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:22.475 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:25.299 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(235.00-1:24.1.0(003)" is not a number
2018-04-27 11:50:25.474 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:27.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:28.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:30.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:31.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:35.474 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:36.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:39.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:40.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:42.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:43.117 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.00-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:50:44.284 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(235.1-0:21.7.0(00.016*kW)" is oversized
2018-04-27 11:50:45.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:46.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:52.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:54.241 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(001-0:32.36.0(00000)" is not a number
2018-04-27 11:50:55.118 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.80-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:50:57.068 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:57.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:58.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:50:59.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:00.484 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 11:51:00.488 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 11:51:00.493 (Slimme Meter Kabel) P1 Smart Meter (Gas)
2018-04-27 11:51:01.467 P1 Smart Meter: Dismiss incoming - value is not delimited in line "0-1:24.2.1(1804271150!705E"
2018-04-27 11:51:04.476 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:06.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:08.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:11.067 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:51:11.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:12.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:13.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:14.469 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 11:51:14.476 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 11:51:15.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:16.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:17.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:18.476 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:21.279 (smartone) P1 Smart Meter (Power)
2018-04-27 11:51:21.280 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:51:21.476 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:25.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:26.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:27.478 (smartone) P1 Smart Meter (Power)
2018-04-27 11:51:27.479 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:51:31.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:32.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:35.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:37.476 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:38.243 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.01-0:32.36.0(00000)" is oversized
2018-04-27 11:51:40.462 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:41.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:45.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:48.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:49.477 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:50.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:53.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:56.464 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:51:57.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:01.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:03.084 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:52:04.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:07.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:08.478 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:10.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:11.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:13.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:15.477 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:16.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:17.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:18.478 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:22.213 P1 Smart Meter: Dismiss incoming - value is not delimited in line "1-0:2.8.2(0"
2018-04-27 11:52:23.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:24.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:26.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:28.477 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:29.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:32.085 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:52:32.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:34.473 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:36.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:37.473 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:38.463 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:39.469 P1 Smart Meter: Dismiss incoming - value is not delimited in line "0-1:24.2.1(180427115007S)(0!350C"
2018-04-27 11:52:40.473 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:41.479 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:42.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:45.260 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.001-0:32.7.0(235.0*V)" is oversized
2018-04-27 11:52:45.466 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:46.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:48.196 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(0-0:96.7.9(00000)" is not a number
2018-04-27 11:52:48.467 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:49.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:50.479 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:53.478 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:55.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:52:57.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:01.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:02.302 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(235.0-1:24.1.0(003)" is not a number
2018-04-27 11:53:04.122 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(0-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:53:04.473 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:07.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:09.070 P1 Smart Meter: WARNING: got new message but buffer still contains unprocessed data from previous message.
2018-04-27 11:53:09.070 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:53:09.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:13.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:14.478 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:16.122 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(50-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:53:19.474 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:20.480 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:24.071 P1 Smart Meter: WARNING: got new message but buffer still contains unprocessed data from previous message.
2018-04-27 11:53:24.072 (smartone) P1 Smart Meter (Power)
2018-04-27 11:53:24.073 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:53:24.073 (smartone) P1 Smart Meter (Gas)
2018-04-27 11:53:24.183 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.2(0000130-0:96.7.21(00002)" is oversized
2018-04-27 11:53:25.473 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:27.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:28.138 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(51-0:2.8.1(000004.900*kWh)" is oversized
2018-04-27 11:53:30.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:32.288 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(21-0:21.7.0(00.018*kW)" is not a number
2018-04-27 11:53:33.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:34.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:36.479 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:38.473 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:40.194 Incoming connection from: 84.106.2.21
2018-04-27 11:53:40.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:41.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:43.468 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:44.123 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(0-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:53:46.470 P1 Smart Meter: Dismiss incoming - value is not delimited in line "0-1:24.2.1(180427115007!D18F"
2018-04-27 11:53:49.087 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:53:49.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:50.474 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:51.479 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:52.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:53.474 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:55.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:56.474 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:53:57.480 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:01.071 P1 Smart Meter: WARNING: got new message but buffer still contains unprocessed data from previous message.
2018-04-27 11:54:01.072 (smartone) P1 Smart Meter (Power)
2018-04-27 11:54:01.073 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:54:01.073 (smartone) P1 Smart Meter (Gas)
2018-04-27 11:54:04.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:05.124 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(50-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:54:06.465 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:09.475 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:11.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:12.475 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:14.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:15.474 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:21.469 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:22.474 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:23.480 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:24.216 P1 Smart Meter: Dismiss incoming - value is not delimited in line "1-0:2.7.0(00.000"
2018-04-27 11:54:27.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:29.480 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:30.199 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.0000-0:96.7.9(00000)" is oversized
2018-04-27 11:54:31.474 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:36.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:38.305 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(20-1:24.1.0(003)" is not a number
2018-04-27 11:54:41.476 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:43.473 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:44.476 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:48.481 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:49.247 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.1-0:32.36.0(00000)" is oversized
2018-04-27 11:54:50.141 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(1-0:2.8.1(000004.900*kWh)" is oversized
2018-04-27 11:54:50.476 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:52.471 (smartone) P1 Smart Meter (Power)
2018-04-27 11:54:52.473 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:54:54.481 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:55.169 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.2(000013.81-0:1.7.0(00.015*kW)" is oversized
2018-04-27 11:54:56.475 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:54:58.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:01.233 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.2(01-0:32.32.0(00000)" is not a number
2018-04-27 11:55:02.475 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:03.291 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(235.1-0:21.7.0(00.015*kW)" is oversized
2018-04-27 11:55:04.471 (smartone) P1 Smart Meter (Power)
2018-04-27 11:55:04.472 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:55:06.477 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:09.475 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:11.089 P1 Smart Meter: Dismiss incoming - CRC value in message has trailing characters
2018-04-27 11:55:11.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:12.096 P1 Smart Meter: Dismiss incoming - value in line "0-1:24.2.1(18042710-0:1.0.0(180427115510S)" is not a number
2018-04-27 11:55:14.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:16.483 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:18.124 P1 Smart Meter: Dismiss incoming - value in line "0-1:24.2.1(180427115504S)(0-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:55:23.473 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:25.482 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:27.475 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:28.482 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:29.183 P1 Smart Meter: Dismiss incoming - value in line "1-0:1.8.2(00001-0:2.7.0(00.000*kW)" is oversized
2018-04-27 11:55:30.475 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:33.169 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.1-0:1.7.0(00.013*kW)" is not a number
2018-04-27 11:55:33.473 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:35.483 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:36.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:38.483 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:39.470 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:40.477 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:42.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:45.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:46.125 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(0-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 11:55:47.483 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:48.473 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:52.476 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:56.482 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:57.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:55:59.292 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(2351-0:21.7.0(00.014*kW)" is oversized
2018-04-27 11:55:59.483 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:01.477 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:02.484 (smartone) P1 Smart Meter (Power)
2018-04-27 11:56:02.485 (smartone) General/Voltage (Voltage L1)
2018-04-27 11:56:04.476 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:05.483 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:06.202 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.000-0:96.7.9(00000)" is oversized
2018-04-27 11:56:07.476 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:08.483 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:09.249 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.7.0(00.01-0:32.36.0(00000)" is oversized
2018-04-27 11:56:10.477 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:11.484 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:14.479 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:15.485 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:16.475 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:19.471 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:22.484 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:27.478 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:28.485 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:29.472 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 11:56:31.484 P1 Smart Meter: Dismiss incoming - CRC failed
luberth
Post by luberth » Friday 27 April 2018 15:37
landis gyr e350 smr5.0 with wireles gasmeter
output from terminal first stop domoticz to get acces to usb
pi@raspberrypi:~ $ sudo service domoticz.sh stop
pi@raspberrypi:~ $ cu -l /dev/ttyUSB0 -s 115200 --parity=none
do not know how to stop it so pulled the usb cable
1-3:0.2.8(50)
0-0:1.0.0(180427153416S)
1-0:1.8.1(000021.843*kWh)
1-0:1.8.2(000008.810*kWh)
1-0:2.8.1(000005.309*kWh)
1-0:2.8.2(000013.841*kWh)
0-0:96.14.0(0001)
1-0:1.7.0(00.000*kW)
0-0:96.7.21(00002)
0-0:96.7.9(00000)
1-0:99.97.0(0)(0-0:96.7.19)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.0()
1-0:32.7.0(235.0*V)
1-0:31.7.0(000*A)
1-0:21.7.0(00.000*kW)
1-0:22.7.0(00.000*kW)
0-1:24.1.0(003)
0-1:24.2.1(180427153005S)(00004.052*m3)
!0D82
/XMX5LGBBLA4415291442
1-3:0.2.8(50)
0-0:1.0.0(180427153417S)
0-0:96.14.0(0001)
0-0:96.7.21(00002)
0-0:96.7.9(00000)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.0()
1-0:32.7.0(235.0*V)
1-0:31.7.0(000*A)
0-1:24.1.0(003)
!4043
1-3:0.2.8(50)
0-0:1.0.0(180427153418S)
0-0:96.14.0(0001)
0-0:96.7.21(00002)
0-0:96.7.9(00000)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.0()
1-0:32.7.0(235.0*V)
1-0:31.7.0(000*A)
0-1:24.1.0(003)
!0F09
1-3:0.2.8(50)
0-0:1.0.0(180427153419S)
0-0:96.14.0(0001)
0-0:96.7.21(00002)
0-0:96.7.9(00000)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.0()
1-0:32.7.0(235.0*V)
1-0:31.7.0(000*A)
0-1:24.1.0(003)
!42C8
1-3:0.2.8(50)
0-0:1.0.0(180427153420S)
0-0:96.14.0(0001)
0-0:96.7.21(00002)
0-0:96.7.9(00000)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.0()
1-0:32.7.0(235.0*V)
1-0:31.7.0(000*A)
0-1:24.1.0(003)
!1090
1-3:0.2.8(50)
0-0:1.0.0(180427153421S)
0-0:96.14.0(0001)
0-0:96.7.21(00002)
0-0:96.7.9(00000)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.0()
1-0:32.7.0(235.0*V)
1-0:31.7.0(000*A)
0-1:24.1.0(003)
!5D51
cu: Got hangup signal
Disconnected.
pi@raspberrypi:~ $
pi@raspberrypi:~ $ sudo service domoticz.sh start
gordonb3
Domoticz version: Custom
Post by gordonb3 » Friday 27 April 2018 16:16
Doesn't look like your electric power registration is working too well either. Loads of CRC errors and the other errors show that you somehow seem to be skipping chunks of data. The data from the direct USB dump looks fine though, so the hardware is most likely good.
You might want to try beta.
luberth
Target OS: Raspberry Pi
Domoticz version: 4.9700
Post by luberth » Friday 27 April 2018 16:31
2018-04-27 16:28:17.484 Domoticz V3.9327 (c)2012-2018 GizMoCuz
2018-04-27 16:28:17.484 Build Hash: 2d82649c, Date: 2018-04-27 09:22:20
2018-04-27 16:28:17.485 Startup Path: /home/pi/domoticz/
2018-04-27 16:28:17.617 Sunrise: 06:15:00 SunSet: 20:59:00
2018-04-27 16:28:17.617 Day length: 14:44:00 Sun at south: 13:05:00
2018-04-27 16:28:17.617 Civil twilight start: 05:36:00 Civil twilight end: 21:38:00
2018-04-27 16:28:17.617 Nautical twilight start: 04:46:00 Nautical twilight end: 22:28:00
2018-04-27 16:28:17.617 Astronomical twilight start: 03:44:00 Astronomical twilight end: 23:30:00
2018-04-27 16:28:17.617 EventSystem: reset all events...
2018-04-27 16:28:17.865 PluginSystem: Started, Python version '3.5.3'.
2018-04-27 16:28:17.876 Active notification Subsystems: (0/14)
2018-04-27 16:28:17.878 WebServer(HTTP) started on address: :: with port 8080
2018-04-27 16:28:17.888 WebServer(SSL) started on address: :: with port 443
2018-04-27 16:28:17.891 Proxymanager started.
2018-04-27 16:28:17.955 Starting shared server on: :::6144
2018-04-27 16:28:17.955 TCPServer: shared server started...
2018-04-27 16:28:17.958 RxQueue: queue worker started...
2018-04-27 16:28:19.958 P1 Smart Meter: Using serial port: /dev/ttyUSB0
2018-04-27 16:28:19.962 P1 Smart Meter: Using serial port: /dev/ttyUSB0
2018-04-27 16:28:19.965 P1 Smart Meter: Using serial port: /dev/ttyUSB0
2018-04-27 16:28:19.968 EventSystem: reset all events...
2018-04-27 16:28:19.969 EventSystem: reset all device statuses...
2018-04-27 16:28:20.127 PluginSystem: Entering work loop.
2018-04-27 16:28:20.729 Python EventSystem: Initalizing event module.
2018-04-27 16:28:20.729 EventSystem: Started
2018-04-27 16:28:20.729 EventSystem: Queue thread started...
2018-04-27 16:28:21.701 P1 Smart Meter: Found gas meter on M-Bus channel 1
2018-04-27 16:28:21.876 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:22.484 P1 Smart Meter: Meter reports as DSMR 5.0
2018-04-27 16:28:23.474 P1 Smart Meter: Meter reports as DSMR 5.0
2018-04-27 16:28:23.870 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:24.701 P1 Smart Meter: Found gas meter on M-Bus channel 1
2018-04-27 16:28:25.865 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:26.871 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:31.866 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:32.872 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:33.702 P1 Smart Meter: Found gas meter on M-Bus channel 1
2018-04-27 16:28:34.484 P1 Smart Meter: Meter reports as DSMR 5.0
2018-04-27 16:28:35.871 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:36.877 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:37.564 P1 Smart Meter: Dismiss incoming - value in line "1-0:2.8.2(01-0:1.7.0(00.015*kW)" is not a number
2018-04-27 16:28:37.865 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:38.519 P1 Smart Meter: Dismiss incoming - value in line "1-3:0.2.8(50-0:96.1.1(4530303435303034303134323932363137)" is oversized
2018-04-27 16:28:39.717 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(236.00-1:96.1.0(4730303339303031383030323534303138)" is oversized
2018-04-27 16:28:40.865 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:44.870 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:45.877 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:46.863 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:48.871 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:52.879 (smartone) P1 Smart Meter (Power)
2018-04-27 16:28:52.881 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:28:52.882 (smartone) P1 Smart Meter (Gas)
2018-04-27 16:28:53.868 (smartone) P1 Smart Meter (Power)
2018-04-27 16:28:53.868 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:28:54.921 (smartone) P1 Smart Meter (Power)
2018-04-27 16:28:54.923 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:28:55.879 (smartone) P1 Smart Meter (Power)
2018-04-27 16:28:55.880 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:28:56.867 (smartone) P1 Smart Meter (Power)
2018-04-27 16:28:56.868 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:28:57.872 (smartone) P1 Smart Meter (Power)
2018-04-27 16:28:57.873 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:28:58.872 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:28:59.878 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:00.869 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:00.871 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:01.873 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:01.875 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:02.879 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:02.880 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:03.868 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:03.869 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:04.873 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:04.874 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:06.528 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:06.530 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:06.868 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:06.869 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:07.873 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:07.874 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:08.878 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:08.878 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:09.869 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:09.870 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:10.874 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:10.875 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:11.888 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:11.890 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:12.871 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:12.872 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:13.871 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:14.879 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:14.880 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:15.866 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:15.867 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:17.344 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:17.346 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:17.879 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:17.880 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:18.867 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:20.864 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:20.865 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:21.866 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:22.871 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:24.868 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:25.872 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:26.878 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:28.872 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:29.878 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:29.879 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:30.869 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:30.870 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:31.873 (smartone) P1 Smart Meter (Power)
2018-04-27 16:29:31.875 (smartone) General/Voltage (Voltage L1)
2018-04-27 16:29:32.878 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:33.867 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:36.879 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:39.864 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:41.872 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:42.702 P1 Smart Meter: Dismiss incoming - value in line "1-0:32.7.0(0-1:24.1.0(003)" is not a number
2018-04-27 16:29:43.868 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:44.879 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 16:29:44.883 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 16:29:44.887 (Slimme Meter Kabel) P1 Smart Meter (Gas)
2018-04-27 16:29:45.873 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:47.869 P1 Smart Meter: Dismiss incoming - value is not delimited in line "0-1:24.2.1(18042716250!8E24"
2018-04-27 16:29:48.872 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:49.878 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:51.873 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:54.873 P1 Smart Meter: Dismiss incoming - CRC failed
2018-04-27 16:29:57.872 P1 Smart Meter: Dismiss incoming - CRC failed
luberth
Re: dutch smartmeter gas usage 4.294.965m3 a day
Post by luberth » Friday 27 April 2018 16:43
ok now beta i think
Version: 3.9327
Compile Date: 2018-04-27 09:22:20
dzVents Version: 2.4.5
Python Version: 3.5.3 (default, Jan 19 2017, 14:11:04) [GCC 6.3.0 20170124]
localhost:8080 doesnt seem to work anymore only background screen in browser(after clear browsing data in chromium localhost works again)
so switched to 127.0.0.1:8080
does not give less crc an faults in log screen
so no improvement
gordonb3
Post by gordonb3 » Friday 27 April 2018 16:57
Hmmm.... Do you have two smart meters setup? I'm seeing `smartone` and `Slimme Meter Kabel`.
luberth
Post by luberth » Friday 27 April 2018 17:04
i have selected the green ones and used the trash icon left above
but the not used green ones come back
are never gone
again checked the checkbox of the green unused ones
pressed the trashcan icon popup realy yes popup removed
but when i go away and comeback the green unused ones are back again
ok i now removed 2 lines from hardware section
i am so stupid
now no errors
2018-04-27 17:20:28.113 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:29.117 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:29.127 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:30.113 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:30.116 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:31.150 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:31.155 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:32.109 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:32.115 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:33.115 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:33.119 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:34.105 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:34.109 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:35.106 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:35.108 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:36.115 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:36.140 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:37.100 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:37.102 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:38.109 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:38.113 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:39.116 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:39.120 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:40.102 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:40.105 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:41.111 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:41.117 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:42.115 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:42.120 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:43.106 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:43.110 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:44.110 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:44.114 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:45.112 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:45.114 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:46.104 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:46.109 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:47.996 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:48.006 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:48.115 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:48.119 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:49.107 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:49.113 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:50.105 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:50.108 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:51.115 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:51.119 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:52.105 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:52.110 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:53.110 (Slimme Meter Kabel) P1 Smart Meter (Power)
2018-04-27 17:20:53.114 (Slimme Meter Kabel) General/Voltage (Voltage L1)
2018-04-27 17:20:54.118 (Slimme Meter Kabel) P1 Smart Meter (Power)
all devices
used devices
luberth
Post by luberth » Friday 27 April 2018 17:26
so problem whas multiple p1 meters in hardware
in settings devices they where unused
but unused is not unused i think
2018-04-27 17:18:37.546 P1 Smart Meter: Serial Worker stopped...
2018-04-27 17:18:43.749 P1 Smart Meter: Serial Worker stopped...
2 unused serial workers made the crc and other faults?
hope my mistakes will help others
gordonb3
Re: dutch smartmeter gas usage 4.294.965m3 a day (problem solved)
Post by gordonb3 » Friday 27 April 2018 19:21
If you have multiple entries in Domoticz listening to the same hardware device, then my guess is that it becomes unpredictable which message part ends up with either instance. As such it appears you've been fragmenting the data from the hardware between those instances and as a result none of them got the complete message. Did you have the additional hardware disabled or only have the corresponding devices set as unused?
luberth
Post by luberth » Saturday 28 April 2018 7:35
i did only have the corresponding devices set as unused
electric graphic day log is also much smoother line now
but have to figure out now how to remove the milions of m3 gas that are in the data
thanks for your help!
gordonb3
Post by gordonb3 » Saturday 28 April 2018 8:08
That explains it then. The hardware will always keep registering, even if you did not enable (all of) the devices that it provides.
luberth
Post by luberth » Saturday 28 April 2018 8:20
pi@raspberrypi:~ $ sudo apt-get update
pi@raspberrypi:~ $ sudo apt-get install sqlitebrowser
now an db browser for sql lite in raspbian accesiores menu
edit domoticz.db
open /home/pi/domoticz/domoticz.db
found some 4milion valeus under meter _calendar changed them to 0
ok milion valeus are out of domoticz log view
