P1 with 3 phase. Development needed.
christiaan.v
Target OS: Raspberry Pi
Post by christiaan.v » Saturday 18 March 2017 23:20
last week i got my P1 meter installed. (smart meter / slimme meter).
I first had it connected via serial USB, works good.
and now via ESP8266 (p1wifi-gateway), also works perfect....
If i look at the MSG from the meter it looks like this:
/ISK5\2M550T-1011
1-3:0.2.8(50)
0-0:1.0.0(170315214802W)
0-0:96.1.1(xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx)
1-0:1.8.1(000061.108*kWh)
1-0:1.8.2(000055.545*kWh)
1-0:2.8.1(000000.000*kWh)
1-0:2.8.2(000000.000*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.687*kW)
1-0:2.7.0(00.000*kW)
0-0:96.7.21(00005)
0-0:96.7.9(00002)
1-0:99.97.0()
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00001)
1-0:52.36.0(00001)
1-0:72.36.0(00001)
0-0:96.13.0()
1-0:32.7.0(231.3*V)
1-0:52.7.0(230.4*V)
1-0:72.7.0(232.2*V)
1-0:31.7.0(000*A)
1-0:51.7.0(002*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.172*kW)
1-0:41.7.0(00.469*kW)
1-0:61.7.0(00.053*kW)
1-0:22.7.0(00.000*kW)
1-0:42.7.0(00.000*kW)
1-0:62.7.0(00.000*kW)
0-1:24.1.0(003)
0-1:96.1.0(xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx)
0-1:24.2.1(170315214506W)(00048.063*m3)
!50B3
This is a DSM 5.0 message. it contains al lot more information then the older versions.
So i was wondering how i can use some of this information.
I have 3 phase connection in the house, each phase serve a different part of the house, so intresting to have these seperated counted.
Currently only the total of 3 phase are counted.
I noticed that someone resently had added the 3 phase voltage counters !!! Nice. currently only in the development brance, but working very nice.
0-0:96.14.0(0002)		<-- Tariff indicator
1-0:32.7.0(231.3*V)		<-- Volt Phase 1 (already on git)
1-0:52.7.0(230.4*V)		<-- Volt Phase 2 (already on git)
1-0:72.7.0(232.2*V)		<-- Volt Phase 3 (already on git)
1-0:31.7.0(000*A)		<-- Ampere Phase 1
1-0:51.7.0(002*A)		<-- Ampere Phase 2
1-0:71.7.0(000*A)		<-- Ampere Phase 3
1-0:21.7.0(00.172*kW)		<-- Power Phase 1
1-0:41.7.0(00.469*kW)		<-- Power Phase  2
1-0:61.7.0(00.053*kW)		<--  Power Phase 3
Who can add the other counters?
Christiaan
haroldp
Re: P1 with 3 phase. Development needed.
Post by haroldp » Wednesday 16 May 2018 12:23
+1 , I would also love to see the 3 Phases Ampere counters in the graphs, very useful information when you sometimes overload one of the groups ;)
enboer
Post by enboer » Tuesday 02 October 2018 16:04
Yes I would like to have this as well. It does not need to be in the graphs, but the P1 smartmeter takes only the first 5 fields from the meter. It would already be fine for me if it would read all the 36 lines (in my case). With scripting I can read it myself.
Running eg a python script to read it as well is not an option, because after this Domoticz does not update the meter anymore
freijn
Post by freijn » Tuesday 02 October 2018 16:26
Can you please share how you connected it with the ESP ?
enboer
Post by enboer » Wednesday 03 October 2018 8:31
I have the smartmeter connected via USB cable (not self build). and Domoticz runs fine. But I have also run this script http://gejanssen.com/howto/Slimme-meter ... itlezer.py to read the USB port as well I see a message: Error serial port close, End of File. After this I need a reboot to get Domoticz to update the meter again.
