New meter
alttab
Target OS: Raspberry Pi
New meter
Post by alttab » Thursday 29 September 2016 6:17
I am moving to a new home with a new smartmeter.
Simple question: what will happen when you connect the new smart power meter to domoticz (p1)? It will start at 0 again. Basically going into the negatives ;)
Will domoticz continue to register the power usage without screwing up the monthly / yearly usage stats?
piotr
Re: New meter
Post by piotr » Thursday 29 September 2016 8:38
No, you will see the actual, current, readings.
alttab
Re: New meter
Post by alttab » Thursday 29 September 2016 18:53
piotr wrote:No, you will see the actual, current, readings.
Thanks, what will happen to the yearly power usage? My old meter is on (for instance) 70000 kwh, new one is on 0 , will it be negative?
Derik
Re: New meter
Post by Derik » Thursday 29 September 2016 19:53
nope
This meter is a perfect [ fucking ] thing...
You get 4 counters.
2 up and 2 download :-)
Every second you use counter x is counting
every second you deliver counter y is counting.
weekend/night and day..
with this 4 counters you must hope the [ salderingsregeling] is still alive for years..[ spring 2017 the gouvernement is voting ]
Other wise your solarpanelparty is over :-(
And your deliver Kwh price is going down to 3-4 cents / KWh [ i think ]
And your use Kwh price is going up...
