decimals for barometer pressure
ricorico94
Target OS: Raspberry Pi
Post by ricorico94 » Thursday 16 February 2017 11:00
I'd like to keep decimals of my pressure measurements, but it seems Domoticz only shows the integer value in graphs and buttons. Is there anyway to configure Domitcz to keep 1 or more decimals ?
I use a BME280 with ESPEasy to feed a virtual sensor in Domoticz. It sends values with decimals to domoticz, but I can't view them on graphs, nor on CSV exports.
Any idea ?
Could we add a setting in the settings/meters menu of Domoticz ?
ricorico94
ricorico94
Re: decimals for barometer pressure
Post by ricorico94 » Sunday 19 February 2017 15:48
Anyone has any idea ?
br,
Ricorico94
stlaha2007
Post by stlaha2007 » Friday 17 March 2017 9:40
Hi ricorico94...
I understand that your feeding a virtual sensor, my first answer would be create e new sensor which accepts decimals e.g. percentage-sensor.
However, most weather-reports i've seen, do NOT contain decimals on the barometric pressure reports.
So there's not an option/setting to change at the moment. Perhaps you can post an enhancement request in the appropiate subforum?
Just quriosity: Why do you want those reports with decimals?
MikeF
Domoticz version: V3.8153
Post by MikeF » Friday 17 March 2017 11:21
This must depend on your set-up, as I'm getting this, using BMP180 / BME280 sensors in MySensors nodes (same with graphs):
(although they're showing different values, they're within 0.3% )
rjblake
Post by rjblake » Wednesday 20 December 2017 10:34
I would like to have the decimals too. There is no problem with the 'Barometer' device (this accepts and shows decimals); but rather with the combination device (in my case the Temp + Humidity + Baro device), which makes things simpler in some respects with having to have fewer devices. I have not tired the other combinations (e.g. Temp+Baro) to see if it is the same.
gwaelod
Post by gwaelod » Saturday 20 January 2018 12:13
I can get the "Barometer" device to show decimals - however I cant get it to show a log of previous output. I can get the Temp/Hum/Baro to show a log of previous output - but wont show decimals in the barometer bit!!
Its frustrating.
Decimals are really needed if uploading to weather sites (Uk Met Office WOW/ACcuweather) for finer resolution of pressure systems.
statusever1
Post by statusever1 » Monday 26 February 2018 17:40
I also want to know dat...
Lampie023
Post by Lampie023 » Monday 21 May 2018 18:48
Yes, please....
I did not find a solution for this so i hope that the developers are reading this..
