[RELEASED] Python plugin to control Onkyo receivers
JimmyH1969
Re: [RELEASED] Python plugin to control Onkyo receivers
Post by JimmyH1969 » Thursday 07 December 2017 12:05
I agree, there's not really a need for it ofcourse, but we have a lot of QSTN commands, so when sending a LMDQSTN for example it should return the current listening mode. When someone wants to create a toggle/prev-next switch for example it would be nice to get the current state and being able to display that in a text sensor for example. I know, this might be a bit to much and is probably not intended to be in Domoticz.
So, At the moment i have no other feature request. The RAW option let's me do whatever i want i guess. Maybe other users have special wishes?
Thanks again!
ronald1977
Target OS: Raspberry Pi
Post by ronald1977 » Monday 01 January 2018 19:25
Varazir wrote:
Tuesday 28 November 2017 23:47
I'm getting this in my log, nothing shows in the device list.
2017-11-28 22:44:19.485 (Onkyo) Started.
2017-11-28 22:44:20.691 (Onkyo) Initialized version 0.2.1, author 'jorgh'
2017-11-28 22:44:20.691 (Onkyo) Entering work loop.
2017-11-28 22:44:32.244 (Onkyo) Receiver found:
2017-11-28 22:44:32.245 (Onkyo) Type: AV Receiver or Stereo Receiver
2017-11-28 22:44:32.245 (Onkyo) Type: TX-NR509
2017-11-28 22:44:32.245 (Onkyo) Region: European or Asian model
2017-11-28 22:44:32.245 (Onkyo) IP adress: 192.168.2.30
2017-11-28 22:44:32.245 (Onkyo) eISCP port: 60128
2017-11-28 22:44:32.246 (Onkyo) MAC: 0009B0C6F4D6
2017-11-28 22:44:34.229 (Onkyo) Loading XML from file
2017-11-28 22:44:34.241 (Onkyo) XML file does not yet exist
2017-11-28 22:44:36.207 (Onkyo) Loading XML from file
2017-11-28 22:44:36.208 (Onkyo) XML file does not yet exist
2017-11-28 22:44:38.215 (Onkyo) Loading XML from file
2017-11-28 22:44:38.216 (Onkyo) XML file does not yet exist
2017-11-28 22:44:40.224 (Onkyo) Loading XML from file
2017-11-28 22:44:40.225 (Onkyo) XML file does not yet exist
2017-11-28 22:44:42.237 (Onkyo) Loading XML from file
2017-11-28 22:44:42.238 (Onkyo) XML file does not yet exist
Hi i have the same problems? I have a tx nr 609, and I have also the error xml file does not yet exit. Is there a fix?
also I can't see nothing in the device list.
pj-r
Domoticz version: V3.8650
Post by pj-r » Wednesday 03 January 2018 1:59
Your receiver(like my 515 also) is too old for this plugin. It doesnt support NRIQSTN-command. Support for NRI was presented in TX NRx2x or NRx3x series.
Instead of this Python plugin try the native Onkyo support(Onkyo AV Receiver (LAN)) in domoticz made by dwmw2(?). Its working now at latest beta also with older receivers without NRI-support. See the previous page in this thread.
And big thanks to dwmw2 for the update! Its working nicely!
pj-r
Post by pj-r » Friday 05 January 2018 1:05
@dwmw2: Would it be hard to add device and learning of radio channels for pre-NRI-devices?
Example what I saw at log when used remote to change radio channels:
(PRSxx=Preset channel at main zone, PRZxx=Preset channel at zone2 ?)
2018-01-05 00:40:18.667 OnkyoAVTCP: Packet received: 6 PRS06
2018-01-05 00:40:18.667 OnkyoAVTCP: Packet received: 6 PRZ06
2018-01-05 00:40:19.667 OnkyoAVTCP: Packet received: 9 TUN10250
2018-01-05 00:40:20.667 OnkyoAVTCP: Packet received: 9 TUZ10250
2018-01-05 00:40:23.668 OnkyoAVTCP: Packet received: 6 PRS05
2018-01-05 00:40:23.668 OnkyoAVTCP: Packet received: 6 PRZ05
2018-01-05 00:40:24.668 OnkyoAVTCP: Packet received: 9 TUN09970
2018-01-05 00:40:25.668 OnkyoAVTCP: Packet received: 9 TUZ09970
2018-01-05 00:40:28.668 OnkyoAVTCP: Packet received: 6 PRS04
2018-01-05 00:40:28.669 OnkyoAVTCP: Packet received: 6 PRZ04
2018-01-05 00:40:29.669 OnkyoAVTCP: Packet received: 9 TUN10160
2018-01-05 00:40:30.669 OnkyoAVTCP: Packet received: 9 TUZ10160
2018-01-05 00:40:31.669 OnkyoAVTCP: Packet received: 6 PRS03
2018-01-05 00:40:31.669 OnkyoAVTCP: Packet received: 6 PRZ03
2018-01-05 00:40:32.669 OnkyoAVTCP: Packet received: 9 TUN09770
2018-01-05 00:40:33.669 OnkyoAVTCP: Packet received: 9 TUZ09770
2018-01-05 00:40:35.670 OnkyoAVTCP: Packet received: 6 PRS02
2018-01-05 00:40:35.670 OnkyoAVTCP: Packet received: 6 PRZ02
2018-01-05 00:40:36.670 OnkyoAVTCP: Packet received: 9 TUN09730
2018-01-05 00:40:37.670 OnkyoAVTCP: Packet received: 9 TUZ09730
dwmw2
Post by dwmw2 » Friday 05 January 2018 1:23
I'm not sure how we'd want to represent those as a device in Domoticz. It's not a simple selector switch like the input selector, since the presets only represent *some* of the available states of the tuner. You can already use the plugin to send PRS00 etc. and hook that up to a dummy switch or script if you want. I think dzVents supports it, although I think some of the dzVents stuff only works if you don't have authentication, which might be a problem.
ronald1977
Post by ronald1977 » Friday 05 January 2018 11:50
Yes I did but then I have only the possibility of switching on and off, volume and zone 2 from my receiver. I would like the possibility of choosing my input (like radio).
I the onkyo app is this possible why not in the plugin?
dwmw2
Post by dwmw2 » Friday 05 January 2018 12:43
Hm, that ought to work. In the models without NRIQSTN it should learn the available input sources as you select them some other way, and after that it should be possible to choose them in Domoticz. With Domoticz running, can you cycle through all the inputs (in each zone) and show me what it does?
ronald1977
Post by ronald1977 » Friday 05 January 2018 21:31
I use the Domoticz V3.8153
This are the things (below) I can see in the log file. How did you do it with your Onkyo receiver?
2018-01-05 20:22:45.261 OnkyoAVTCP: Send PWRQSTN
2018-01-05 20:22:45.262 OnkyoAVTCP: Send MVLQSTN
2018-01-05 20:22:45.262 OnkyoAVTCP: Send ZPWQSTN
2018-01-05 20:22:45.262 OnkyoAVTCP: Send ZVLQSTN
2018-01-05 20:22:45.262 OnkyoAVTCP: Send SLIQSTN
2018-01-05 20:22:45.262 OnkyoAVTCP: Packet received: 9 NLSC-P
2018-01-05 20:22:46.262 OnkyoAVTCP: Packet received: 8 PWR01
2018-01-05 20:22:46.263 OnkyoAVTCP: Packet received: 8 MVL37
2018-01-05 20:22:46.264 OnkyoAVTCP: Packet received: 8 SLI23
2018-01-05 20:22:46.264 OnkyoAVTCP: Packet received: 8 ZPW00
2018-01-05 20:22:46.265 OnkyoAVTCP: Packet received: 9 ZVLN/A
2018-01-05 20:22:46.279 (Onkyo Receiver) Light/Switch (Onkyo Power)
2018-01-05 20:22:46.283 (Onkyo Receiver) Light/Switch (Zone 2 power)
Xavier82
Domoticz version: V3.8153
Post by Xavier82 » Saturday 06 January 2018 21:28
I also use the Domoticz V3.8153 (on Synology).
I use the "Onkyo AV Receiver (LAN)" as default implemented in this version.
After entering correct settings (IP-adres of my Onkyo TX-NR414 (PRE-NRI) and port (60128) ).
I get the same:
What I did to get the switches in Domitcz is simply:
1. In Domoticz go to setup and make sure Domoticz is accepting new hardware/sensors.
2. Go to your Onkyo amplifier and put it on.
3. Now simply press 1 by 1 (one after each other) all the functions like Cab/sat/ Dvd/FM/USB/NET/whatever.
4. Turn the volume up/down for a bit.
5. Go back to Domoticz and now check your logg, you can now see that Domoticz received data.
6. Go in Domoticz to the Devices and Add the new devices to the switches.
7. Done
I hope I can help some people with this information.
Regards,
Xavier
ronald1977
Post by ronald1977 » Monday 08 January 2018 19:17
I get the same:
7. Done
Regards,
Xavier
Till step 5 it goes good ;-), I can see in the log that he receives the other inputs.
But then by Devices I don't see the devices? Is there another solution?
This is the log.
2018-01-08 18:11:04.477 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:04.477 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:04.477 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:04.477 OnkyoAVTCP: Packet received: 8 SLI10
2018-01-08 18:11:07.478 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:07.478 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:07.478 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:08.478 OnkyoAVTCP: Packet received: 8 LMD84
2018-01-08 18:11:08.478 OnkyoAVTCP: Packet received: 8 SLI00
2018-01-08 18:11:10.479 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:10.479 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:10.479 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:10.479 OnkyoAVTCP: Packet received: 8 LMD0C
2018-01-08 18:11:10.479 OnkyoAVTCP: Packet received: 8 SLI01
2018-01-08 18:11:12.479 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:12.479 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:12.479 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:12.479 OnkyoAVTCP: Packet received: 8 LMD89
2018-01-08 18:11:12.479 OnkyoAVTCP: Packet received: 8 SLI02
2018-01-08 18:11:14.480 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:14.480 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:14.480 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:15.480 OnkyoAVTCP: Packet received: 8 LMD0C
2018-01-08 18:11:15.480 OnkyoAVTCP: Packet received: 8 SLI05
2018-01-08 18:11:16.481 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:16.481 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:16.481 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:17.481 OnkyoAVTCP: Packet received: 8 SLI03
2018-01-08 18:11:18.481 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:18.482 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:18.482 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:18.482 OnkyoAVTCP: Packet received: 8 SLI24
2018-01-08 18:11:18.482 OnkyoAVTCP: Packet received: 11 TUN09470
2018-01-08 18:11:20.482 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:20.482 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:20.482 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:20.482 OnkyoAVTCP: Packet received: 8 LMD84
2018-01-08 18:11:21.483 OnkyoAVTCP: Packet received: 8 SLI23
2018-01-08 18:11:25.483 OnkyoAVTCP: Packet received: 31 NLTF300000000070000FFFF00NET
2018-01-08 18:11:25.483 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:25.483 OnkyoAVTCP: Packet received: 30 NLSU0-vTuner Internet Radio
2018-01-08 18:11:25.483 OnkyoAVTCP: Packet received: 31 NLSU1-Last.fm Internet Radio
2018-01-08 18:11:25.483 OnkyoAVTCP: Packet received: 16 NLSU2-Napster
2018-01-08 18:11:25.484 OnkyoAVTCP: Packet received: 16 NLSU3-Spotify
2018-01-08 18:11:25.484 OnkyoAVTCP: Packet received: 30 NLSU4-AUPEO! PERSONAL RADIO
2018-01-08 18:11:25.484 OnkyoAVTCP: Packet received: 21 NLSU5-My Favorites
2018-01-08 18:11:25.484 OnkyoAVTCP: Packet received: 13 NLSU6-DLNA
2018-01-08 18:11:25.484 OnkyoAVTCP: Packet received: 8 LMD13
2018-01-08 18:11:26.484 OnkyoAVTCP: Packet received: 8 SLI2B
2018-01-08 18:11:26.484 OnkyoAVTCP: Packet received: 9 NLSC-P
2018-01-08 18:11:26.484 OnkyoAVTCP: Packet received: 8 LMD0C
2018-01-08 18:11:27.484 OnkyoAVTCP: Packet received: 8 SLI40
2018-01-08 18:11:29.485 OnkyoAVTCP: Packet received: 31 NLTF00100000000000002FF00USB
2018-01-08 18:11:29.485 OnkyoAVTCP: Packet received: 9 NLSC0P
2018-01-08 18:11:29.485 OnkyoAVTCP: Packet received: 16 NLSU0-No Item
2018-01-08 18:11:29.485 OnkyoAVTCP: Packet received: 8 SLI29
2018-01-08 18:11:35.486 OnkyoAVTCP: Packet received: 9 NLSC-P
2018-01-08 18:11:35.486 OnkyoAVTCP: Packet received: 8 SLI24
2018-01-08 18:11:35.486 OnkyoAVTCP: Packet received: 11 TUN09470
2018-01-08 18:11:37.487 OnkyoAVTCP: Packet received: 8 MVL2B
2018-01-08 18:11:37.488 OnkyoAVTCP: Packet received: 8 MVL2D
2018-01-08 18:11:37.492 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:37.496 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:38.488 OnkyoAVTCP: Packet received: 8 MVL2C
2018-01-08 18:11:38.489 OnkyoAVTCP: Packet received: 8 MVL2B
2018-01-08 18:11:38.494 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:38.498 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:39.490 OnkyoAVTCP: Packet received: 8 MVL2A
2018-01-08 18:11:39.491 OnkyoAVTCP: Packet received: 8 MVL2C
2018-01-08 18:11:39.496 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:39.500 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:40.492 OnkyoAVTCP: Packet received: 8 MVL2D
2018-01-08 18:11:40.493 OnkyoAVTCP: Packet received: 8 MVL2C
2018-01-08 18:11:40.498 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:41.096 (rf) Temp (Tempratuur Buiten)
2018-01-08 18:11:41.494 OnkyoAVTCP: Packet received: 8 MVL2A
2018-01-08 18:11:41.495 OnkyoAVTCP: Packet received: 8 MVL2B
2018-01-08 18:11:41.500 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:41.503 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:42.496 OnkyoAVTCP: Packet received: 8 MVL2A
2018-01-08 18:11:42.501 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:43.497 OnkyoAVTCP: Packet received: 8 MVL2B
2018-01-08 18:11:43.502 (Onkyo) Light/Switch (Master volume)
2018-01-08 18:11:44.498 OnkyoAVTCP: Packet received: 8 MVL2A
2018-01-08 18:11:44.503 (Onkyo) Light/Switch (Master volume)
Xavier82
Post by Xavier82 » Monday 08 January 2018 22:44
I get the same:
7. Done
Regards,
Xavier
This is the log.
Go to settings and Devices (apparaten) and afd them by selecting the blue arrow (becomes green) buttons are now added
ronald1977
Post by ronald1977 » Tuesday 09 January 2018 9:05
[/quote]
[/quote]
Thx, but I don't see in settings and by devices the other onkyo (apparaten)devices like my radio input. :?
Are you using the Onkyo plugin maybe or Onkyo Lan? I used the Onkyo Lan and in my log I can see that he see my radio source.I hope you have another solution.
Xavier82
Post by Xavier82 » Tuesday 09 January 2018 10:46
I use Onkyo LAN (not the plugin)...
In devices tab I can see Volume and master on and off and also the input selectie... will try to make a screenshot later today...
ronald1977
Post by ronald1977 » Tuesday 09 January 2018 16:24
Okee I am curious.
Xavier82
Post by Xavier82 » Tuesday 09 January 2018 16:54
@ronald1977
I need to make my apologize.....
Production server is running 3.8153 and indeed devices are not being created...
On test server I'm running version 3.8804 (since today-->> auto update), in this version (beta) Onkyo devices (like Input Selector) are created..
Sorry for the inconvenience....
ronald1977
Post by ronald1977 » Tuesday 09 January 2018 17:53
@ronald1977
Ahh so i have to wait then for a new version.
rizzah
Post by rizzah » Friday 26 January 2018 19:08
When updating to the latest beta the server crashes when running the onkyo parts.
When reverting back to the lastest stable i see these errors in the log:
2018-01-26 17:58:58.012 Error: (Onkyo) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
Could it be something could crash the latest beta because of the onkyo part?
biggles
Post by biggles » Saturday 17 February 2018 20:45
HI,
I have run into a small issue.
One of the inputs of the onkyo is at number 110. So if i try to select that input with blocks i cant because the level only goes up to 100%.
Is there a workaround for that ?
Regards,
Biggles.
JimmyH1969
Post by JimmyH1969 » Sunday 18 February 2018 16:06
You can move the inputs up and down when you modify the selectorswitch. Moving the desired input up at a level below 100 should do the trick.
biggles
Post by biggles » Monday 26 February 2018 23:33
Thanks Jimmy, that did the trick.
But this still leaves the problem with not being able to select a level higher then 100 %.
Regards,
Biggles.
Users browsing this forum: No registered users and 5 guests
