Yeelight and Hue lights - use same settings
bertbigb
Post by bertbigb » Tuesday 21 February 2017 13:45
I was asked to share my Lua script by LouiS22 in item http://www.domoticz.com/forum/viewtopic ... 82#p120482 Re: [Plugin now available in Beta] Help with Yeelight Bulb
The script below is what I found, combined, tried myself with the purpose
-- Lua script to set Philips Hue and Yeelights to the same Brightness, HUE and saturation parameters
-- First to adjust all the bulbs to the same values
-- Second to find out what values will suite me, debug = true and in the log file the commands are printed
-- copy paste the values you like and use them in your more "final" program
I hope this will others help also
I created a few "virtual" dimmer switches
Dimmer Switches.png (256.5 KiB) Viewed 3779 times
and a selector switch
Selector Switch.png (150.71 KiB) Viewed 3779 times
In the code you see a lot of comment, I do this for myself to document the code with explanation
and this is the code for the script:
-- Lights
-- copy paste the ones you like and use them in your more "final" program
YEELIGHTS
    PART OF YEELIGHT MANUAL (for Reference pasted here)
    complete manual can be found at http://www.yeelight.com/download/Yeelight_Inter-Operation_Spec.pdf
    Method: set_hsv
    Usage: This method is used to change the color of a smart LED.
    Parameters: 4.
    "hue" is the target hue value, whose type is integer. It should be
    expressed in decimal integer ranges from 0 to 359.
    "sat" is the target saturation value whose type is integer. It's range is 0
    to 100.
    "effect": Refer to "set_ct_abx" method.
    "duration": Refer to "set_ct_abx" method.
    Request Example: {"id":1,"method":"set_hsv","params":[255, 45, "smooth", 500]}
    Method: set_bright
    Usage: This method is used to change the brightness of a smart LED.
    Parameters: 3.
    "brightness" is the target brightness. The type is integer and ranges
    from 1 to 100. The brightness is a percentage instead of a absolute value. 100 means
    maximum brightness while 1 means the minimum brightness.
    Request Example: {"id":1,"method":"set_bright","params":[50, "smooth", 500]}
    Response Example: {"id":1, "result":["ok"]}
    NOTE: Only accepted if the smart LED is currently in "on" state.
    Method: set_power
    Usage: This method is used to switch on or off the smart LED (software
    managed on/off).
    Parameters: 3.
    "power" can only be "on" or "off". "on" means turn on the smart LED,
    "off" means turn off the smart LED.
    Request Example: {"id":1,"method":"set_power","params":["on", "smooth", 500]}
    Method: start_cf
    Usage: This method is used to start a color flow. Color flow is a series of smart
    LED visible state changing. It can be brightness changing, color changing or color
    temperature changing. This is the most powerful command. All our recommended scenes,
    e.g. Sunrise/Sunset effect is implemented using this method. With the flow expression, user
    can actually “program” the light effect.
    Parameters: 3.
    "count" is the total number of visible state changing before color flow
    stopped. 0 means infinite loop on the state changing.
    "action" is the action taken after the flow is stopped.
    0 means smart LED recover to the state before the color flow started.
    1 means smart LED stay at the state when the flow is stopped.
    2 means turn off the smart LED after the flow is stopped.
    "flow_expression" is the expression of the state changing series.
    Request Example: {"id":1,"method":"start_cf","params":[ 4, 2, "1000, 2, 2700, 100, 500, 1,
    255, 10, 5000, 7, 0,0, 500, 2, 5000, 1"]
    NOTE: Each visible state changing is defined to be a flow tuple that contains 4
    elements: [duration, mode, value, brightness]. A flow expression is a series of flow tuples.
    So for above request example, it means: change CT to 2700K & maximum brightness
    gradually in 1000ms, then change color to red & 10% brightness gradually in 500ms, then
    stay at this state for 5 seconds, then change CT to 5000K & minimum brightness gradually in
    500ms. After 4 changes reached, stopped the flow and power off the smart LED.
    START CF Command explanation
    {"id":1,"method":"start_cf","params":[ 4, 2, "1000, 2, 2700, 100, 500, 1, 255, 10, 5000, 7, 0,0, 500, 2, 5000, 1"]
    Example explained
    {"id":1,"method":"start_cf", 	--start colour flow
    "params":[ 4, 					--count, after 4 changes stop
    2, 								--action, "action" is the action taken after the flow is stopped.
    								--the next values in pairs 0f 4 means
    								--[duration, mode, value, brightness].
    								--mode = COLOR_MODE": Current light mode. 1 means color mode, 2 means color temperature, mode, 3 means HSV mode.
    "1000,							--change from present state in 1000ms
    2, 								--color temperature mode
    2700, 							--color temperature 2700
    100, 							--brightness 100
Philips HUE Lights
    usefull links:
    http://192.168.2.8/debug/clip.html
    https://developers.meethue.com/documentation/getting-started
    https://www.domoticz.com/forum/viewtopic.php?t=10493
	https://www.domoticz.com/wiki/Philips_Hue_Lights
    http://huelights.com/
    values:
    Sat = Saturation a value between 0 and 255
    Bri = Brightness a value between 0 and 255
    Hue = Hue, color a value between 0 and 65535
Yeelight Hue Lights
	usefull links:
	http://forum.yeelight.com/c/wonder
	https://www.domoticz.com/wiki/Yeelight
    values:
    Sat = Saturation a value between 0 and 100
    Bri = Brightness a value between 1 and 100
    Hue = Hue, color a value between 0 and 359
    --CHANGE BELOW FOR YOUR OWN NEEDS
    SelectorDevice1 = 'Lights-Selector'
    SelectorDevice2 = "Lights-Scene"
    DimDevice = 'Dimmer';
    TempDevice = 'WhiteTemp'
    HueDevice = 'Hue'
    SatDevice ='Sat'
    BriDevice ='Bri'
    DurationDevice ='Duration' --here you set the duration of the Dimmer Cycle 100% = 100 seconds, 10% = 10 seconds
	--YEELIGHT
    -- port number for the yeelights
    PORT = '55443'
    --IP adresses of the bulbs involved,
    local IPs = {'192.168.2.80', '192.168.2.81', '192.168.2.82', '192.168.2.83', '192.168.2.84', '192.168.2.85'}
	--PHILIPS HUE LIGHTS
	--ID of the Philips Hue of the bulbs involved; 1 = hanglamp, 3 = kamer-kast
	local BulB = {'1', '3'}
    bridge_ip_address ="192.168.2.8"
    hue_api_user = "2uZavYOxxxxxxxxxxxxTLGlHxxxxxxNGA"
    debug = true
	StartColorFlow = false
	synology = true
    function round(num, numDecimalPlaces)
      local mult = 10^(numDecimalPlaces or 0)
      return math.floor(num * mult + 0.5) / mult
	function HueOff()
		-- command Philips Hue Off
		for n,bulb_id in pairs(BulB) do
			-- concatenate the http part of the command for HUE
			http = " http://" .. bridge_ip_address .. "/api/" .. hue_api_user .. "/lights/" ..bulb_id.."/state"
			runcommandHue = "curl --request PUT --data '{\"on\":false}'"
			os.execute(runcommandHue..http)
	function YeelightOff()
		--command Yeelight Off
		for n,IP in pairs(IPs) do
			runcommandYeelight = "sudo echo -ne '{\"id\":"..n..",\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | /opt/bin/nc -w1 " ..IP.." " ..PORT.."";
			os.execute(runcommandYeelight)
	function HueOn()
			runcommandHue = "curl --request PUT --data '{\"on\":true}'"
	function YeelightOn()
			runcommandYeelight = "sudo echo -ne '{\"id\":"..n..",\"method\":\"set_power\", \"params\":[\"on\", \"smooth\", 500]}\\r\\n' | /opt/bin/nc -w1 " ..IP.." " ..PORT.."";
	function HueTemperature(WhiteHue, DimHue, DurationHue)
		--HUE part
			--concatenate the command part of the command for HUE
			runcommandHue = "curl --request PUT --data '{\"on\":true, \"transitiontime\":"..DurationHue..", \"ct\":" ..WhiteHue.. ", \"bri\":" ..DimHue .."}'"
			if debug then print(runcommandHue..http) end
	function YeelightTemperature(WhiteYee, DimYee, DurationYee)
		--Yeelight part
		    --runcommandYeelight = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\",\"params\":[\"ct\", " .. WhiteYee .. "," .. DimYee .. "]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
			--runcommandYeelight = "sudo echo -ne '{\"id\":1,\"method\":\"set_ct_abx\",\"params\":[" .. WhiteYee .. ",\"smooth\","..DurationYee.."]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
			runcommandYeelight ="sudo echo -ne '{\"id\":"..n..",\"method\":\"start_cf\",\"params\":[1,1,\"" ..DurationYee..",2,"..WhiteYee..","..DimYee.."\"]}\\r\\n' | /opt/bin/nc -w1 " ..IP.." " ..PORT.."";
			if debug then print(runcommandYeelight) end
	function HueHue(HueHue, SatHue, BriHue, DurationHue)
			runcommandHue = "curl --request PUT --data '{\"on\":true, \"transitiontime\":"..DurationHue..", \"sat\":" ..SatHueValue.. ", \"bri\":" ..BriHueValue ..",\"hue\":" ..HueHueValue .."}'"
	function YeeHue(HueYee, SatYee, BriYee, DurationYee)
		--Yeelight part
			if StartColorFlow then
				runcommandYeelight = "sudo echo -ne '{\"id\":"..n..", \"method\":\"start_cf\", \"params\":[1,1,\"" ..DurationYee..",3,".. HueYee .. "," .. SatYee ..","..BriYee.."\"]}\\r\\n' | /opt/bin/nc -w1 " ..IP.." " ..PORT.."";
				--since color flow on Yeelight for HSV mode is not working, we need to send 2 commands, 1 for the hue and satuartion and 1 for brightness
				--command for the Yeelight Hue Example: {"id":1,"method":"set_hsv","params":[255, 45, "smooth", 500]}  --> hue, sat, effect, duration
				runcommandYeelight = "sudo echo -ne '{\"id\":"..n..", \"method\":\"set_hsv\", \"params\":[" .. HueYee .. ", " .. SatYee .. ", \"smooth\", "..DurationYee.."]}\\r\\n' | /opt/bin/nc -w1 " ..IP.." " ..PORT.."";
				--command for the Yeelight brightness Example: {"id":1,"method":"set_bright","params":[50, "smooth", 500]} --> brightness, effect, duration
				runcommandYeelight = "sudo echo -ne '{\"id\":"..n..", \"method\":\"set_bright\", \"params\":[" .. BriYee ..  ", \"smooth\", "..DurationYee.."]}\\r\\n' | /opt/bin/nc -w1 " ..IP.." " ..PORT.."";
    --see if one of the sliders was changed
    if devicechanged[HueDevice] or devicechanged[SatDevice] or devicechanged[BriDevice] or devicechanged[TempDevice] or devicechanged[DimDevice] or devicechanged[DurationDevice]then
        --there are changes in the settings, so estimate the values for each type of the bulbs
	    TempValue = otherdevices_svalues[TempDevice];
	    BriValue = otherdevices_svalues[BriDevice]
	    SatValue = otherdevices_svalues[SatDevice]
	    HueValue = otherdevices_svalues[HueDevice]
	    DimValue = otherdevices_svalues[DimDevice];
	    DurationValue = otherdevices_svalues[DurationDevice];
	    --to prevent errors for nil values when initiated
        if TempValue==nil then TempValue=0 end
        if BriValue==nil then BriValue=0 end
	    if SatValue==nil then SatValue=0 end
	    if HueValue==nil then HueValue=0 end
	    if DimValue==nil then DimValue=0 end
	    if DurationValue==nil then DurationValue=0 end
	    if debug then print("Temp = " ..TempValue.." Dim = "..DimValue.." Bri = "..BriValue.." Sat = "..SatValue.." Hue = "..HueValue.." Duration = "..DurationValue) end
	    --determine the duration of the transation, 100% = 100 seconds, 10% = 10 seconds, 1% = 1 sec
        if DurationValue == 0 or DurationValue == nil then
            DurationHueValue = 4    --standard transation time Hue = 400 ms
            DurationYeeValue = 400  -- make Yeelights have the same value as Philips Hue Lights
            DurationHueValue = DurationValue * 10       -- Hue Transation time is defined in 0,1 sec
            DurationYeeValue = DurationValue * 1000     -- Yee transation time is in ms = 0,001 sec
        --color changes
        BriHueValue = round(tonumber(BriValue * 2.55),0);
        SatHueValue = round(tonumber(SatValue * 2.55),0);
        HueHueValue = round(tonumber(HueValue * 655.35),0);
        BriYeeValue = tonumber(BriValue)
        SatYeeValue = tonumber(SatValue)
        HueYeeValue = round(tonumber(HueValue * 3.59),0);
        --white changes
        --Yeelight Temp between 1700 and 6500 Kelvin
        WhiteYeeValue = ((TempValue-1) * 48)+1700;
        DimYeeValue =  tonumber(DimValue)
        --Huelight value between the warmest color 2000K is 500 mirek ("ct":500) and the coldest color 6500K is 153 mirek ("ct":153)
        WhiteHueValue = 500 - round(tonumber(TempValue * 3.47),0)
        DimHueValue = round(tonumber(DimValue * 2.55),0)
        if (devicechanged[HueDevice]=='Off' or devicechanged[SatDevice]=='Off' or devicechanged[BriDevice]=='Off' or
            devicechanged[TempDevice]=='Off'or devicechanged[DimDevice]=='Off') or
		    (tonumber(otherdevices_svalues[BriDevice]) ==0 or tonumber(otherdevices_svalues[SatDevice])==0 or tonumber(otherdevices_svalues[HueDevice])==0 or
		        tonumber(otherdevices_svalues[TempDevice])==0 or tonumber(otherdevices_svalues[DimDevice])==0 ) then
			-- the bulb is Off
			HueOff()
			YeelightOff()
		if devicechanged[TempDevice] or devicechanged[DimDevice] then
		    --there was change at Lighttemperature setting so we need to send that commands
			HueTemperature(WhiteHueValue, DimHueValue, DurationHueValue)
            YeelightTemperature(WhiteYeeValue, DimYeeValue, DurationYeeValue)
		    --there were changes in the color settings so send the proper commands for that case
			HueHue(HueHueValue, SatHueValue, BriHueValue, DurationHueValue)
			YeeHue(HueYeeValue, SatYeeValue, BriYeeValue, DurationYeeValue)
    if devicechanged[SelectorDevice1] then
        if otherdevices['HueSun'] == 'On' then commandArray['HueSun'] = 'Off' end
        if otherdevices['Staande schemerlamp'] == 'Off' then commandArray['Staande schemerlamp'] = 'On' end
        HueOn()
        YeelightOn()
        print("selectorswitch")
        if otherdevices[SelectorDevice1] == "Energize" then
            commandArray[TempDevice]='Set Level 99'
            commandArray[DimDevice]='Set Level 90'
        if otherdevices[SelectorDevice1] == "Concentrate" then
            commandArray[TempDevice]='Set Level 77'
            commandArray[DimDevice]='Set Level 80'
        if otherdevices[SelectorDevice1] == "Reading" then
            commandArray[TempDevice]='Set Level 44'
            commandArray[DimDevice]='Set Level 70'
        if otherdevices[SelectorDevice1] == "Normal" then
            commandArray[TempDevice]='Set Level 37'
            commandArray[DimDevice]='Set Level 60'
        if otherdevices[SelectorDevice1] == "Relax" then
            commandArray[TempDevice]='Set Level 16'
            commandArray[DimDevice]='Set Level 10'
        if otherdevices[SelectorDevice1] == "Movie" then
            commandArray[TempDevice]='Set Level 100'
            commandArray[DimDevice]='Set Level 30'
        if otherdevices[SelectorDevice1] == "Romantic" then
            commandArray[TempDevice]='Set Level 12'
        --[[ some test results for later reference
        HUE SAT BRI - description
          4  60  42 - rose
          7  65  19 - yellow-ish
          3  65  19 - orange /red
         10  65  19 - yellow/green
         20  65  19 - green/yellow
         30  65  19 - green
         40  65  19 - green/blue
         50  65  19 - bue/green - light blue
         60  65  19 - blue
         70  65  19 - deep blue
         76  65  19 - night blue
         80  65  19 - purple
         90  65  19 - purple / red
        100  65  19 - red
        if otherdevices[SelectorDevice1] == "Warm" then
            commandArray[HueDevice]='Set Level 4'
            commandArray[SatDevice]='Set Level 60'
            commandArray[BriDevice]='Set Level 42'
        if otherdevices[SelectorDevice1] == "NightBlue" then
            commandArray[HueDevice]='Set Level 76'
            commandArray[SatDevice]='Set Level 65'
            commandArray[BriDevice]='Set Level 19'
        if otherdevices[SelectorDevice1] == "Warm-Dimmed" then
            commandArray[HueDevice]='Set Level 99'
        if otherdevices[SelectorDevice1] == "Off" then
        	HueOff()
			YeelightOff()
Best regards Bert
Synology DS1515+ - DSM 6.1
Raspberry PI2 - B, Raspberry Nano - Raspberry PI3 - model B
hekm77
Target OS: Raspberry Pi
Re: Yeelight and Hue lights - use same settings
Post by hekm77 » Friday 24 February 2017 8:48
Тhanks. I deleted "Hue line" from code. Works fine only for Yeelight.
bertbigb
Post by bertbigb » Friday 24 February 2017 9:19
hekm77 wrote:Тhanks. I deleted "Hue line" from code. Works fine only for Yeelight.
Nice to hear you could make use of the script. Enjoy!
Best regards Bert
Derik
Post by Derik » Saturday 07 October 2017 14:08
dear all.
Old post only...
Is there some one that can help me with a "simple"srcipt for the Yeelight.
I will try to make different scripts working:
http://4pda.ru/forum/index.php?showtopi ... 58350704-1
Sunset sunrise etc..
Only how do i use this codes?
a lua and then?
or?
damirch
Post by damirch » Wednesday 01 November 2017 10:03
Hi, Can you please share your script?
Thanks.
hekm77
Post by hekm77 » Wednesday 01 November 2017 10:35
damirch
Post by damirch » Wednesday 01 November 2017 18:57
Hi.
http://4pda.ru/forum/index.php?act=find ... 58660929-5
Thank you, script works.
But... everything is really slow, any change takes long time to complete and in Domoticz logs i see:
2017-11-01 17:55:58.435 Error: EventSystem: Warning!, lua script Yeelight-Scene has been running for more than 10 seconds
EdwinK
Post by EdwinK » Wednesday 01 November 2017 21:34
a lot of things.
What do I use in the settings for the selector-switchs?
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
hekm77
Post by hekm77 » Saturday 11 November 2017 1:29
Updated the script to dzVents 2.3.0. Only for Yeelight RGB Bulb
Test it.
NegerT
Domoticz version: 3.8153
Post by NegerT » Tuesday 12 December 2017 15:08
For those still interested in this thread, I made some adjustments to the script to use it on my windows installation. Also added netcat and bash on windows to run it.
Removed all but one dimmer switch as well since I don't use them and made some changes in the way the Yeelights are turned on (tends to be faster).
-- Windows requirements:
--      -netcat for windows
--      -bash enabled
--Fixed IP addresses for the Yeelights
--[[ FOR OWN REFERENCE
    values:
      4  60  42 - rose
     30  65  19 - green
     60  65  19 - blue
     80  65  19 - purple
    100  65  19 - red
debug = false
--[[        Needed Switches         ]]--
SelectorDevice1 = 'Livingroom Scene'
Dimmer1         = 'Livingroom dimmer'
    --[[        PHILIPS HUE LIGHTS         ]]--
	--ID of the Philips Hue bulbs involved
    local BulB = {'xxx','xxx', 'xxx'}
	--IP and API of Hue bridge
    bridge_ip_address ="xxx"
    hue_api_user = "xxx"
    --[[        YEELIGHT LIGHTS         ]]--
    PORT = '55443'
    local IPs = {'xxx', 'xxx', 'xxx'}
--PROGRAM
--[[            Yeelight commands           ]]--
    local Yeelight_command={}
    Yeelight_command_total = ""
	    Yeelight_command[n] = "C:\\Windows\\Sysnative\\bash.exe -c \"sudo echo -ne '{\\\"id\\\":"..n..",\\\"method\\\":\\\"set_power\\\",\\\"params\\\":[\\\"off\\\"]}\\\\r\\\\n' | nc -w1 " ..IP.." " ..PORT.."\"";
	    --Yeelight_command[n] = "C:\\Windows\\Sysnative\\bash.exe -c \"sudo echo -ne '{\\\"id\\\":"..n..",\\\"method\\\":\\\"toggle\\\",\\\"params\\\":[]}\\\\r\\\\n' | nc -w1 " ..IP.." " ..PORT.."\"";
        print("Yeelight "..n.." turned off")
	    Yeelight_command_total = Yeelight_command_total..Yeelight_command[n].." & "
	if debug then
        print(Yeelight_command_total);
    os.execute(Yeelight_command_total);
function YeelightTemperature(WhiteYeeValue, DimYeeValue, DurationYeeValue)
	    Yeelight_command[n] = "C:\\Windows\\Sysnative\\bash.exe -c \"sudo echo -ne '{\\\"id\\\":"..n..",\\\"method\\\":\\\"set_scene\\\",\\\"params\\\":[\\\"ct\\\","..WhiteYeeValue..","..DimYeeValue.."]}\\\\r\\\\n' | nc -w1 " ..IP.." " ..PORT.."\"";
	    print("Yeelight "..n.." turned on")
	if debug then
function YeelightHue(BriYeeValue, SatYeeValue, HueYeeValue, DurationYeeValue)
        Yeelight_command[n]= "C:\\Windows\\Sysnative\\bash.exe -c \"sudo echo -ne '{\\\"id\\\":"..n..",\\\"method\\\":\\\"set_scene\\\",\\\"params\\\":[\\\"hsv\\\"," .. HueYeeValue .. "," .. SatYeeValue .. ","..BriYeeValue.."]}\\\\r\\\\n' | nc -w1 " ..IP.." " ..PORT.."\"";
	if debug then
function YeelightBright(BriYeeValue)
        Yeelight_command[n]= "C:\\Windows\\Sysnative\\bash.exe -c \"sudo echo -ne '{\\\"id\\\":"..n..",\\\"method\\\":\\\"set_bright\\\",\\\"params\\\":["..BriYeeValue..",\\\"smooth\\\", 500]}\\\\r\\\\n' | nc -w1 " ..IP.." " ..PORT.."\"";
        print("Yeelight "..n.." changed brightness")
	if debug then
--[[            Hue light commands           ]]--
function HueOff()
		http = " http://" .. bridge_ip_address .. "/api/" .. hue_api_user .. "/lights/" ..bulb_id.."/state "
	    runcommandHue = "curl -H \"Accept: application/json\" -X PUT -d \"{\\\"on\\\":false}\""
        print("Huelight "..bulb_id.." turned off")
        if debug then
            print(runcommandHue..http);
		os.execute(runcommandHue..http.."");
function HueTemperature(WhiteHueValue, DimHueValue, DurationHueValue)
		runcommandHue = "curl -H \"Accept: application/json\" -X PUT -d \"{\\\"on\\\":true,\\\"transitiontime\\\":"..DurationHueValue..",\\\"ct\\\":" ..WhiteHueValue.. ",\\\"bri\\\":" ..DimHueValue .."}\""
        print("Huelight "..bulb_id.." turned on")
        if debug then
function HueHue(BriHueValue, SatHueValue, HueHueValue, DurationHueValue)
		runcommandHue = "curl -H \"Accept: application/json\" -X PUT -d \"{\\\"on\\\":true,\\\"transitiontime\\\":"..DurationHueValue..",\\\"sat\\\":" ..SatHueValue.. ",\\\"bri\\\":" ..BriHueValue ..",\\\"hue\\\":" ..HueHueValue .."}\""
        if debug then
function HueBright(BriHueValue)
		runcommandHue = "curl -H \"Accept: application/json\" -X PUT -d \"{\\\"bri\\\":" ..BriHueValue .."}\""
        print("Huelight "..bulb_id.." changed brightness")
        if debug then
    print("Livingroom lights scene was set to = "..devicechanged[SelectorDevice1])
        --Scene values
        DurationValue = 8;                                                  --value defined as x times 0,1 sec
            TempValue = 99;
	        DimValue = 90;
	        Method = 1;
            TempValue = 77;
	        DimValue = 80;
	        Method = 1;
            TempValue = 44;
	        DimValue = 70;
	        Method = 1;
            TempValue = 37;
	        DimValue = 60;
	        Method = 1;
            TempValue = 16;
	        DimValue = 10;
	        Method = 1;
            TempValue = 100;
	        DimValue = 30;
	        Method = 1;
            TempValue = 12;
	        DimValue = 10;
	        Method = 1;
            BriValue = 42;
	        SatValue = 60;
	        HueValue = 4;
	        Method = 2;
            BriValue = 19;
	        SatValue = 65;
	        HueValue = 76;
	        Method = 2;
            BriValue = 19;
	        SatValue = 65;
	        HueValue = 99;
	        Method = 2;
        	HueOff()
        	YeelightOff()
	        if BriValue==nil then BriValue = DimValue end
	        commandArray[Dimmer1]='Set Level '..BriValue
            DimHueValue = round(tonumber(DimValue * 2.55),0)                    --Huelight value between the warmest color 2000K is 500 mirek ("ct":500) and the coldest color 6500K is 153 mirek ("ct":153)
            DurationHueValue = DurationValue                                    --Hue Transation time is defined in 0,1 sec
            WhiteYeeValue = ((TempValue-1) * 48)+1700;                          --Yeelight Temp between 1700 and 6500 Kelvin
            DurationYeeValue = DurationValue * 100                              --Yee transation time is in ms = 0,001 sec
            if Method == 1 then
                print("Temperature Value = " ..TempValue..", Dimmer Value = "..DimValue.."")
            elseif Method == 2 then
                print("Brightness Value = "..BriValue..", Saturation Value = "..SatValue..", Hue Value = "..HueValue.."")
    if devicechanged[Dimmer1] and Method == nill then
            BriValue = otherdevices_svalues[Dimmer1]
            print("Brightness = "..BriValue.."")
damirch
Post by damirch » Wednesday 10 January 2018 10:04
Test it.
Hello
I'm testing it but I don't know what to put here:
local Light = domoticz.devices('YeeVisoki') -- Yeelight Bulb
hekm77
Post by hekm77 » Wednesday 10 January 2018 10:19
local Light = domoticz.devices('Name_of_your_lamp_from_the_device_tab')
damirch
Post by damirch » Wednesday 10 January 2018 10:25
Problem is I have 8 Yeelight lamps and if i put only one here i can turn off only that one lamp. How can I add all 8 lamps?
hekm77
Post by hekm77 » Wednesday 10 January 2018 10:55
local Lights = {'name1', 'name2', 'name3'}
for n, name in pairs(Lights) do
domoticz.devices(name).switchOn()
damirch
Post by damirch » Wednesday 10 January 2018 12:02
Thanks. I guess I'm doing something wrong.
Can you please attach whole file?
Thank you very much for your effort!
hekm77
Post by hekm77 » Wednesday 10 January 2018 13:41
damirch
Post by damirch » Wednesday 10 January 2018 13:57
Sorry, I can not help with this.
http://www.domoticz.com/wiki/DzVents:_n ... _scripting
http://www.domoticz.com/wiki/LUA_commands
Ok, Thanks.
I'm switching to older version which works for me. Hopefully someone in the future will post working script.
My scripting knowlegde is limited :)
Anyway, thank you!
damirch
Post by damirch » Wednesday 10 January 2018 17:05
Anybody who can fix this for me? I'll pay :)
Users browsing this forum: No registered users and 4 guests
