Domoticz Update failed
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
salopette
Target OS: Raspberry Pi
Domoticz version: V3.6882
Post by salopette » Wednesday 10 October 2018 18:12
Version V4.9700 last BETA
Platform: Pi
Plugin/hardware: RF Link
pi@raspberry3:~ $ curl -L install.domoticz.com | sudo bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 194 100 194 0 0 787 0 --:--:-- --:--:-- --:--:-- 785
100 16257 100 16257 0 0 26196 0 --:--:-- --:--:-- --:--:-- 26196
::: You are root.
::: Update option selected.
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for libcurl3... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for sudo... installed!
::: Checking for cron... installed!
::: Checking for libudev-dev... installed!
::: Downloading Domoticz
::: Current User: pi
::: Destination folder=/home/pi/domoticz
--2018-10-10 18:07:40-- http://www.domoticz.com/download.php?channel=release&ty pe=release&system=linux&machine=armv7l
Auflösen des Hostnamens »www.domoticz.com (www.domoticz.com)« … 185.27.142.198
Verbindungsaufbau zu www.domoticz.com (www.domoticz.com)|185.27.142.198|:80 … ve rbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 301 Moved Permanently
Platz: https://www.domoticz.com/download.php?c ... ase&system =linux&machine=armv7l [folgend]
--2018-10-10 18:07:40-- https://www.domoticz.com/download.php?channel=release&t ype=release&system=linux&machine=armv7l
Verbindungsaufbau zu www.domoticz.com (www.domoticz.com)|185.27.142.198|:443 … v erbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 302 Moved Temporarily
Platz: https://releases.domoticz.com/releases/ ... armv7l.tgz [folgend]
--2018-10-10 18:07:40-- https://releases.domoticz.com/releases/release/domoticz _linux_armv7l.tgz
Auflösen des Hostnamens »releases.domoticz.com (releases.domoticz.com)« … 2a03:b 0c0:0:1010::480:1001, 146.185.159.228
Verbindungsaufbau zu releases.domoticz.com (releases.domoticz.com)|2a03:b0c0:0:1 010::480:1001|:443 … ^C
pi@raspberry3:~ $ cd domoticz
pi@raspberry3:~/domoticz $ sudo ./domoticz
2018-10-10 18:09:05.376 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2018-10-10 18:09:05.377 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2018-10-10 18:09:05.377 Status: Startup Path: /home/pi/domoticz/
2018-10-10 18:09:05.384 Error: Database incompatible with this Domoticz version . (You cannot downgrade to an old Domoticz version!)
Koensk
Re: Domoticz Update failed
Post by Koensk » Wednesday 10 October 2018 19:23
Whats your question?
Verstuurd vanaf mijn moto x4 met Tapatalk
SweetPants
Domoticz version: V4.10067
Post by SweetPants » Wednesday 10 October 2018 20:28
V4.9700 is NOT last beta. V4.10055 is (10/10/2018)
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
salopette
Post by salopette » Wednesday 10 October 2018 20:50
I can not make an update on the WebUi, which shows update is available, starts to load it down and then comes an error
I have the last beta V4.10053 from this afternoon
Koensk
Post by Koensk » Wednesday 10 October 2018 21:12
Have you tried to update using ssh?
SweetPants
Post by SweetPants » Thursday 11 October 2018 11:15
cd ~/domoticz
./updatebeta
sudo systemctl restart domoticz.service
salopette
Post by salopette » Thursday 11 October 2018 16:32
yes ssh can do that, but web ui does not work anymore and i do not know why?
Koensk
Post by Koensk » Thursday 11 October 2018 19:34
And if you sudo reboot? Does your web ui work again?
salopette
Post by salopette » Thursday 11 October 2018 20:49
yes, when Pi restarts, Domoticz works
Mr-Leo
Post by Mr-Leo » Friday 12 October 2018 14:42
Got the same problem, looks like there is a problem connecting to releases.domoticz.com
Updating from domoticz:
Error while downloading Update,
check your internet connection or try again later !...
Updating from ssh (./updatebeta)
Connecting to releases.domoticz.com (releases.domoticz.com)|2a03:b0c0:0:1010::480:1001|:443... (time out)
Vox1100
Post by Vox1100 » Saturday 13 October 2018 9:47
Got the same problem.
Updating from ssh (./updatebeta) oké
SweetPants
Post by SweetPants » Saturday 13 October 2018 11:51
Looks like the site is hacked? http://releases.domoticz.com produces a comodore 64 blue screeen
Vox1100
Post by Vox1100 » Sunday 14 October 2018 12:48
Its Hackt?
Commodore 64?
Commodore 64?
harolds
Post by harolds » Sunday 14 October 2018 15:36
Looks like its been hacked... The IPv6 download does not work anymore. Force using the IPv4 via /etc/hosts does fix the download issue (for now):
/etc/hosts:
146.185.159.228 releases.domoticz.com
I do hope that the domoticz release images are not compromised (we don't want to have some trojan in our home control software!)
Users browsing this forum: No registered users and 6 guests
