Install Domoticz on new raspbian/debian stretch
sznupi
Re: Install Domoticz on new raspbian/debian stretch
Post by sznupi » Sunday 10 September 2017 18:54
Installing libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb from http://mirrordirector.raspbian.org/rasp ... o/openssl/ seems to solve the issue (the libs posted above are apparently compiled against armv7)
johanm
Target OS: Raspberry Pi
Post by johanm » Monday 11 September 2017 15:24
I started all over again. I was not sure about the status and installed versions of libssl anymore. And removing versions and install new ones did not bring any good results for me.
Did not do any customisation after restarting the fresh Raspbian Stretch-lite build!
Installed the above mentioned libsll:
wget http://mirrordirector.raspbian.org/raspbian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
and Domoticz (stable)
sudo curl -L install.domoticz.com | sudo bash
Now it is working (without illegal instruction or libssl messages) :D
From here I will start with the customisation of the PI (Network, Mosquitto, NodeJS, NodeRed etc).
Thanks for the help!
jeje77
Domoticz version: 2.4031
Post by jeje77 » Monday 11 September 2017 20:14
1.
cd domoticz
./updaterelease
2.
3.
Works for me :)
wlevels
Domoticz version: V4.9700
Post by wlevels » Tuesday 12 September 2017 7:55
1.
cd domoticz
./updaterelease
2.
3.
Works for me :)
Works for me to :)
sonar
Domoticz version: 3.8153
Post by sonar » Tuesday 12 September 2017 20:27
If I install the libssl1.0.0 with dpkg when using the release version it works again.
When I update to beta I get the following error.
 domoticz.sh[4390]: Illegal instruction
bigsmooth
Post by bigsmooth » Friday 15 September 2017 8:36
I have same issue.
I don't if it is hardware specific, but I am trying to install it on a RPI 1.
My two cents.
Regards,
Olivier
strebor
Domoticz version: 8007
Post by strebor » Friday 15 September 2017 9:57
I read somewhere that there is an issue with the compilation of the ssl package ARM6/7 wise so it's going to be hardware specific if that's true. I reverted to jessie as I needed a working on Pi2 system.
Regards Strebor
jannl
Post by jannl » Friday 15 September 2017 10:52
I only find some issues about Stretch on a pi1, on my Pi3 everthing I use works fine. I connect with the Domoticz app via HTTPS.
hasseb
Post by hasseb » Wednesday 20 September 2017 20:23
Hi, I also got "Connection Refused" after a clean install of the latest raspbian and the latest domoticz.
I used the latest RASPBIAN STRETCH WITH DESKTOP and then the curl line to install domoticz from a terminal in X.
The above suggestions solved my issue for the non secure http://<myip>:8080 or http://127.0.0.1:8080
I used
cd ~
wget http://ftp.nl.debian.org/debian/pool/main/o/openssl/libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb
sudo dpkg -i libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb
sudo service domoticz restart
sudo service domoticz start
And it worked! Thanks a lot guys! :-)
skipi
Post by skipi » Friday 13 October 2017 21:45
Thank you so much!
JuanUil
Domoticz version: 2.xx
Post by JuanUil » Monday 16 October 2017 19:03
I did all the above mentioned.
I backed-up my database.
Uploaded it after install and then about 5 z-wave sensors and switches are not recognised.
tried again and again even with older back-ups but get the same result.
Any help?
Jan
JuanUil
Post by JuanUil » Tuesday 17 October 2017 19:58
Nobody?
jannl
Post by jannl » Tuesday 17 October 2017 21:38
Use a backup of your zwfg config file.
RichardBokker
Domoticz version: 3.9317
Post by RichardBokker » Wednesday 31 January 2018 0:27
I used
cd ~
still works today!
thnx,
blauwebuis
Domoticz version: current
Post by blauwebuis » Saturday 10 February 2018 15:37
still works
CafedelmarNL
Post by CafedelmarNL » Sunday 18 February 2018 22:54
Perfect!, Got 2 day same issues, thx a lot!
manta99
Post by manta99 » Tuesday 20 February 2018 23:10
I notice there were at least three people here unable to get Stretch working on the RPi 1/B. I came to this thread with the same problem.
The latest stable 8153 Domoticz gave me the 'illegal instruction' error post installation when requesting status and no browser access.
None of the libssl versions posted earlier worked for me, but eventually I found this one;
wget http://mirror.nl.leaseweb.net/raspbian/raspbian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u7_armhf.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u7_armhf.deb
My RPi B (ARM1176JZF-S processor to be clear) is now working fine, at least with HTTP, not currently HTTPS, but still feels like a win to me!
Raspberry Pi B, RFXtrx433E, Somfy, KaKu, Smartwares, Weather Underground, Unbranded Thermometer/Hygrometer,
Owl Energy Monitor
SjoerdNLD
Post by SjoerdNLD » Sunday 18 March 2018 10:52
I can confirm that when installing on my 1/B with latest Stretch has the same problem;
Installing the below works!
Arsenius
Post by Arsenius » Friday 23 March 2018 16:00
Today i reinstalled my raspberry and i had the same issue.
After applying the libssl version you suggest and running the beta-update; http would work but for https i would get the error:
Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
Error: WebServer(SSL) check privileges for opening ports below 1024
i changed the /etc/init.d/domoticz.sh file to run https on port 8081, then run the init.d startup script and i was able to reach the https webinterface.
jannl
Post by jannl » Friday 23 March 2018 16:40
My init.d script is run as root. 443 is allowed then.
