Central Heating Monitoring with graph and TV, email notification.
Gerry123
Target OS: Raspberry Pi
Post by Gerry123 » Friday 05 October 2018 17:52
If anyone is interested I will post the code for the following requirement -
1 - Monitor time/hr a central heating burner is on.
2 - Monitor the external temperature/hr.
3 - Monitor the used oil/hr.
4 - Output 1-3 in graphical form each day.
5 - Output predefined minimum oil alarm via Samsung TV message alert & email.
I am not a developer, just a hobbyist & their will be improvements as the project was a learning experience in Domoticz,Lua,Blockly,EspEasy,Bash,GnuPlot, & a little Python.
Graph attached.
Kind Regards,
Gerry.
EdddieN
Domoticz version: 4.9700
Re: Central Heating Monitoring with graph and TV, email notification.
Post by EdddieN » Friday 05 October 2018 21:09
Similar setup. What do you show on the TV?
Also, how do you measure the oil?
11101101 - www.machinon.com
Gerry123
Post by Gerry123 » Saturday 06 October 2018 20:47
attached tv message, HC-sr04 US Sensor
Samsung TV Message.jpg (89.47 KiB) Viewed 244 times
EdddieN
Post by EdddieN » Sunday 07 October 2018 13:40
This one?
https://www.sparkfun.com/products/13959
Wow! I must admit I’m not that comfortable making holes on the tank yet.
How have you found accuracy so far? I understand that temperature plays a fair bit....
what about weather proofing the device and power?
Gerry123
Post by Gerry123 » Sunday 07 October 2018 18:01
Similiar - https://www.amazon.co.uk/ELEGOO-Ultraso ... ds=hc-sr04
Accuracy from memory is +/- 3cm. However their is significant jitter. This is managed in Lua by -
local LDistance_MaxChange = tonumber(LDistance1 + (LDistance1 * 7.5/100)) --Local Variables
local LDistance_MinChange = tonumber(LDistance1 - (LDistance1 * 7.5/100)) --Local Variables
if (tonumber(LDistance) > LDistance_MinChange and tonumber(LDistance) < LDistance_MaxChange) then
commandArray['Variable:VDistance1']= tostring (LDistance)
{where LDistance is the HC-sro4 distance & VDistance1 is the stored value}
Sorry. I cannot take picture of device mounting (weather here quite unpleasant}
2 holes drilled in a cap of a 20 litre container, hc-sr04 pushed through inside of cap holes, cap has a 120*6 mm bolt mounted inside, fuel tank filling lid drilled with 6mm hole, cap secured to inside of fuel tank lid. Weatherproof accomplished.
Power was convenient as burner was quite close.
Users browsing this forum: No registered users and 4 guests
